ok todayi took my dash off so i could put my new CF thigns in. i took out my cd player to see how my new one would look in there and now my car wont turn over. please help me, i need to go to school tomorrow. i disconnected the battery for like 35 minutes....
thanks for the help.
FOR SALE: (5) '95-'99 Z24 Rims
Turn the key to on, but don't start it. Sit in your car for about 10 minutes with your key on and it should go out. Then start yer car. If you would have searched, you would have found this.
^^ hey man i apprechiate the help. i searched and it came up with some stuff about 00+ . im sorry i didnt search hard enough.
well i went out there after i left the key turned on for 10 minutes and it still had the lock on and wont start
now what?
now the damn thing just makes a ticking noise when i try and turn it over. also the radio dont even turn on. what i dont udnerstand is that when i had the radio undone...the plugged it back in....i was listening to the radio right afterwards, and it started up. idk whats going on.
sounds like you have a dead battery. Charge it up
will that fix the theft lock problem?
Could be a drained battery or even a disconnect harness behind he dash, i'm sure you checked all the connectinons right. Try changing the battery or hooking it to a charger, then try to start it. What did you remove or disconnect to work on the car?
ok, i took the dash off. put my things on...disconnected the cd player. plugged it back in, then turned it on to see if it worked...it did. then i put eveything on. then i think i started it to try and get some heat (its freezing out). then i finished and then tried to turn it on and the theft light came on. i actually think it came on once before that but i just turned it on and it went. so after this time of me not being able to turn it on....i just d/ced the battery for a while. and it still didnt work. then i left it on for like 20 to see if it turned off like lanman said. that didnt work. and now thats where i am. im pretty sure thats the order of everything. now the headlights wont even turn on and stuff so i think its a dead battery but that still dont solve my theft lock problem. so ill charge it tomorrow then do whatever else you guys suggest. thanks.
Sounds like your root problem is that dead battery. If the anti-theft was being tripped, the car would start and then die right away. Charge that battery and then I bet your problems will be solved.
-Chris
then id check the theft lock harness going in to the instument cluster, theres 3 of them to the right of the cluster. look and make sure you didnt accidently disconect it, and make sure you didnt rip the wires out. the only thing i can think of besides the battery being dead. altho it makes me wonder how the battery got dead.
and if the theft lock still kicks in when you try and start the car (once the battery is charged also by the way) email me and ill tell you how to totaly disable the theft lock system.
Yea, the clicking sound is defintly a dead battery, used to happen to me all the time.
Heres your problem, You blew the fuses under your hood that say "Batt 1" or Batt 2" maybe both, check them out
Thats right, keep on killing innocent people and @!#$ everything up for others..YOU ARE TEH WIN
^^ ok how do i tell....dont they turn dark? thanks everyone when i get home im going to charge up the battey....try and start....if that dont work ill rip the dash off again.
also i remember messing with those wires to the right of the cluster to see if i could take the whole thing off but it was stuck...so maybe i loosened a connection.
Did you charge your battery yet?
yeah i got it going guys. thanks a lot to all of you. anyone wanna tell him how you know a fuse is blow though....just something i would like to know.
Easiest way is to take a mulitmeter or test light and test one side of the fuse and then the other. If you get the same reading on both sides, it's good, if you get different readings, the fuse is blown.
-Chris
Brian Anderson {1999-Z24-4spd} wrote:yeah i got it going guys. thanks a lot to all of you. anyone wanna tell him how you know a fuse is blow though....just something i would like to know.
Besse wrote:Easiest way is to take a mulitmeter or test light and test one side of the fuse and then the other. If you get the same reading on both sides, it's good, if you get different readings, the fuse is blown.
The Easiest way is to pull the fuse out, hold it up to the light and see if there is a break in the peice of metal you see, look for some black charring as well.
So I assume I was correct?
If you know exactly which fuse to look at, that might be ok, but what if you aren't sure? Using a test light or MM is a quick and easy way to check any or all of your fuses quickly.
-Chris
This is also true, However if you arent lucky enough to have a test light handy than you can narrow the problem down..something like this...
"My car wont start"....that probably wouldnt be a headlight fuse. ya know
So get out the fuse box diagram on the door and start your search.
If a broad number of things doesnt work than check your fuses under the hood
so what was wrong with the car?? anyone know??
Wojo wrote:so what was wrong with the car?? anyone know??
Probably blew the fuse under the hood that says "Batt2"
ok same things is happening to me. i plugged in the remote wire on the head unit to the one from the amp and the one on the harness....then i had my passenger door open for a while because i was installing some racing seats. well the headlamp went out. i closed the door then opened and it worked. but when i tried to start the car it wouldnt. check engine light came on and theft system. i waited like 10 minutes inside the car doors locked keys in my pocket. when i went to go turn it on it still wouldnt. then i sorta pressed the break pedal and messed around with the heat knob...then it turned on....i turned it off and on a couple of times and then drove like 30 yards. when i parked it it would not turn on again. like nothing cranks or anything..
then when i took my key out the check engine light stayed on and the miles of the car were on as well. WEIRD!!! i didnt know that when you press the key cylinder in the dome light turns on. but anyways...my car is not turning on right now...what to do??
"Sunfire got stolen, all i have is the J to remember it by"
