Okay when you buy something try to get directions, I know. I just got the 95-99 toyota tail lights and when I look at my wires I have that single bulb and three wires as the jdm has the brake and turn of course. I'm by all means not asking someone to put them in just if you've done it before can you please give me some pointers and tips? Thanks.
                         Car under construction
 http://www.cardomain.com/ride/2366291
SEARCH!!!!!!!! this has been discussed a million times!!!!! there is even a link that has a full description and pictures!!!!!!!!!
2002 Cavalier 2200----- Buffalo, NY
That's awsome, but I stated before I would just like some pointers!
I'm by all means not asking someone to put them in just if you've done it before can you please give me some pointers and tips? Thanks. But here is perfect example of bashing! If you've done this install just help out if not please keep your comments to yourself. It's obvious i've done as much as I could and I am pretty well informed just if you have a certain trick or what not. It  would be helpfull!
                                      Thanx again.
well I've got em in they look awsome. Junior I understand about work, and it isn't as easy as it seems. I had to seach of course but all I found was
  wiring technics. I did how ever looked in the haynes manuel and found out how to cut the brake out of the turn signal, and then simply tied into the third brake light. I really could have used that magic wond though.
