im looking at getting 2  12s nad i was wondering whats better???? a mono amp or a  2 channel amp bridged???
What subs are you looking at? Single or dual voice coil? What impedence?
-Chris
wait, mono and bridged 2 channel amps are for 1 sub right?
they are single coil subs
Kase (Alex) wrote:wait, mono and bridged 2 channel amps are for 1 sub right?
As long as you match the impedence correctly, you can use as many subs as you want.
Freddy Drake wrote:they are single coil subs
Most likely they will be 4 ohm subs, but check them to make sure. If they are 4ohm, your best bet is to run them in parallel at 2 ohms to a mono amp, Most 2 channel are stable to 4 ohms when bridged.
-Chris
yea ther 4 ohm subs. is ther a way i can put one sub per channel on the 2 channel??   and if i do run them parallel on a mono, does the power get divided by 2??
i have a 2 channel amp, with a sub on each channel.  It owrks fine.
Yes, it will work, you just won't get the full potential out of the amp. Class D amps are also more power efficent than class A/B.
-Chris
