i wanted to try and build my own box this time and was got to looking at the carstereo.com and i just cant figure out how to figure out all this stuff
what i wanted to to build the box for was for 2 12" Type R's the 1222D's is the model.
I wanted to build a ported box but cant figure out the box dimmensions or the slot length or the port so i need help really bad with this one.
can i get help with that tool because 74.75 deep is that right?
if your talking about tone that is quite high for spl, try to get it into the lower areas anywhere between 20 -40 hz.
Well i am trying to use that as well and with a 6x6 port im getting 76hz.  Which i dont want.   So hopfully im using it correctly.
The port area it asks for, is that area of the tube.
For example its 6in in diamater so i have a area of 26 Sq/In.
Sound right?
thats not my tone my tone was 29 hz i belive it is one of the measurments on the box. It was the box measurement i believe is what they meant by deep.
jbodycavalier03 wrote:Quote:
it automatically applies a depth measurement to give you your needed airspace that you typed in.
You supply height and width and airspace needed, it gives you back the depth required to achieve that airspace.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Now is that going to make my sub a one note wonder?
What if id really like to reuse my current box and use the aero ports....can it be done?
also is there anything wrong with adding plexi to the front of the box?
Edited 1 time(s). Last edited Monday, July 03, 2006 6:36 AM
Rosario wrote:Now is that going to make my sub a one note wonder?
The box I did above is for jbodycavalier03
Whay would you think that it would be a one note wonder??????? It says right on the page that it's tuned @ 32 hz!! That is NOT one note wonder tuning.
You can just add ports to your current box if there is enough airspace. But if it's a sealed box...more than likely it will not have enough.
You can add plexi...uit just has to be really thick or else it's going to flex and cause alot of resonation.
 RE Audio
RE Audio
Lash, we are using the same subs, so i figured the box would work for me as well.
I understand its tuned to 32hz but alot of people complain about going that low because it isnt good for daily use, mainly comp only.  Thats why i asked you, you seem to know your @!#$.
Currently each chamber of my box is 1.5 Cu/Ft  To small?
And thanks for the advice on the plexi, thats what i was unsure of was how much it would flex.
Who says this????????? That is COMPLETELY WRONG! Higher tuning = comp use!!!!
1.5 is gonna be too small for 12's. After sub and port displacement...it'll be around 1.2-1.3 cubes...or les.
 RE Audio
RE Audio
Other online audio forums....
So that box you posted should work for me correct?
The box i came up with for jbodycavy....was 5cubes @30hz. with about 60 sq in of port if i remember correctly. (two 12's)
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
I like it but i dont wanna go that big, so im gunna go with the first design.  Where do the subs go?  Above the slot?  or on the back side so the slot is opposite to the subs
Rosario wrote:Other online audio forums....
Where?? I wanna see this...lol.
 RE Audio
RE Audio
Rosario wrote:I like it but i dont wanna go that big, so im gunna go with the first design.  Where do the subs go?  Above the slot?  or on the back side so the slot is opposite to the subs
Put them on the same axis as the port...so put the port and subs firing the same way.
 RE Audio
RE Audio
Thanks!
Sounddomain is a big one, i think the other is car stereoforum.com or something along those lines.  That just seems to be the big thing, is that they think is you tune it that low then its worthless for daily use.   But i see now that they are wrong.
I think you may have just misunderstood or read it wrong.
 RE Audio
RE Audio
