I can't for the life of me get my amp and subs to work w/ this CD player!!!!!  If you have it, how did you connect the REM from the amp.  I'm terrible w/ audio but this shouldn't be so hard! So who's got it and how'd you do it? Thanks!
well i had the jvc KD ar360 ...should hook up the same...sorry but all i did was run the remote wire straight to it
it should be the blue wire with the white stripe. /
I ran it to a blue wire, didn't work....there isn't one w/ a white stripe.  Also there isn't a spot for it on the back of the headunit!   Help!
EASY FIX.....  HOW ABOUT YOU BYPASS THE HEAD UNIT AND INSTALL A SWITCH.  I HAVE THAT BECAUSE OF THE SOUND VIOLATION LAWS IN IL.  I CAN FORWARD YOU A COPY OF THE INSTILLATION OF MY SWITCH. IN IT WOULD BE POWER WIRE, GROUND, SWITCH, RCA'S, ECT.  LET ME KNOW.
I tried doing that and id didn't work.   Does anyone know how or where to connect the REM to this headunit?? need help asap i wanna get his done
found the blue and white wire, hooked up the REM, still doesn't work.........
run it right to the ignition wire off the headunit.  it will be red on the harness.  it will turn your amp on when the car comes on and off when the car is off.
and please fuse your wire
I got it now guys, it was the blue and white wire. Thanks
Yup.. usually a pure blue wire is for a power antenna, not enough amperage to turn on the amp although it is 12v. Glad to hear you got it to work man.
