i have a 2002 cavalier and it came with the trunk pop button under the stereing wheel. i am installing a autopage RF-520lcd keyless entry system it has all relays on board. what wires do i connect and to what to use my new remote to pop the trunk.
sorry im new
try bulldog security's website for the wire info, and for how to use it, read your manual
drivers kick panel, black wire with white stripe....that goes straight to the solenoid
The black wire at the BCM is a Positive trip Black/white..Or you can go to the back of the switch and it is still black/ white but it is a negative trip..
like everybody else has said, black/white wire
here's the wire diagram for the car.
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|lt. blue            |*2 |either kick panel           |
|     POWER UNLOCK|white               |*2 |either kick panel           |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |harness to rear, dkp        |
|       HEADLIGHTS|dk. blue            |-  |headlight switch            |
|     DOOR TRIGGER|grn/blk & lt. blue  |-  |*3                          |
|  TRUNK/HATCH PIN|black               |-  |trunk light                 |
|TRNK/HTCH RELEASE|black/white         |+  |BCM *4                      |
|       TACHOMETER|purple/white        |   |engine harness *1           |
|       BRAKE WIRE|white               |+  |stop light switch           |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |LF window motor in door     |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers kick panel          |
|  LR WINDOW UP/DN|dk. green - purple  |A  |drivers kick panel          |
|  RR WINDOW UP/DN|lt. green - purple  |A  |drivers kick panel          |
Notes:
NOTE: This vehicle has the passlock II immobilizer system  *1 The engine harness is found next to the battery, below the radiator hose, just above the transaxle.   *2 Non keyless cars, locks are 5wi (type C) and they are mastered from the passenger side switch. Keyless cars, locks are positive trigger (type A). Also found at BCM.  *3 The green/black is located in the lower drivers kick panel. It catches the drivers door only. The light blue is located in the lower passenger kick panel, and catches the passenger door(s). Tap both wires and diode isolate each. Also found at BCM.  *4 The BCM is located to the left of the steering column above the kick panel.
This information can be found
here.
