I recently changed back to a stock cd player in my car.  I got tired of my nice Apline decks getting stolen.  But this time around I would like to get one sub and of course an amp.  But when it comes to knowledge about what kind of amp should go with the sub, I'm clueless.  So I have some questions.
I got a Alpine Type S (10") from a buddy for free...so I couldn't pass that up.
SPECIFICATIONS
Power Handling
 Power Handling Capacity (Peak) : 900W
 Power Handling Capacity (RMS) : 300W
General
 Diaphragm Material : Aluminum Coated Poly and Kevlar Reinforced Pulp
 Displacement Frount mounted : 0.095 cu.ft.
 Displacement Rear mounted : 0.123 cu.ft.
 Frame Design : Deep Draw with Vented Leg/Spider Plateau, Integrated Terminal Landing
 Gasket Design : Injection Moulded Hidden Screw Design with Front/Rear Sealing
 Magnetic Weight : 72oz.
 Motor Structure Configuration and Pole Geometry : Extended Dual Flare Pole Vent, Compound Radius Curve (Patent #6, 639, 993)
 Mounting Depth (top mount) : 164mm (6.6")
 Mounting Diameter (top mount) : 274mm (11")
 Optimum Sealed Box Volume : 1.25 cu.ft.
 Optimum Vented Box Volume : 1.5 cu.ft.
 Recommended Box Types : Sealed/Vented/Bandpass
 Recommended Sealed Box Volume : 0.85 - 1.5 cu. ft.
 Spider Material : Nomexฎ
 Surround Design and Material : High Excursion Tapered Half-Roll, Injection Moulded Santopreneฎ
 Terminal Type : Heavy Duty 8ga. Push with Housing, Banana Plug Jumper
 Vented Box Volume Range, Vent Diameter Length : 1.25-2.0 cu.ft., 4" ID x 12" Long
 Voice Coil Design : 4-Layer Dual Voice Coil
 Voice Coil Diameter : 38mm (1.5")
And I was looking at this amp....
SPECIFICATIONS
RMS Power: 400W x 1 (at 2 ohms)
Bridged Power: 600W x 1 (at 4 ohms)
1 Channel (Mono) Operation
Thermal Management Processor
Subsonic Filter
Bass EQ Circuit
Selectable Crossover (LP)
Adjustable Crossover (LP)
MOSFET Power Supply
DC-DC PWM Power Supply
Discrete Pre-Amp Stage
MOSFET Final Outputs
STAR Circuitry
Auto Over-Current Protection
Top Mounted Blue LED Power/Status Indicator
Gold Plated RCA Input Connectors
Continuously Adjustable Gain Control
Speaker Level Inputs
Gold Plated Power Screw Terminals
Gold Plated Speaker Terminals
Non-Fading Pre-Amp Output
Dual Sided Glass Epoxy PC Board
CEA-2006 compliant
Any good?  If not, what would be the best amp to run for this one sub?
Thanks in advance guys!
