I have an Alpine CDA9856, and was wondering which wire is the turn on lead. I searched and found that the blue/white could be it, but that is bieng used, I have a solid blue that is free, then a pink(im pretty sure that isn't it). Could i be the solid blue?
Ok, the blue/white is remote but will the blue also work? the power ant? I don't have a power ant and will it only work if am/fm are on?
just use the blue/white wire.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
It is being used already by the harness.
Do you not have the install manual that came with the HU?
If you don't, try alpine's website.
Though remote turn on is usually blue and usually marked as REM
It is the blue with white stripe on it. If you are already using it (to what i don't know) disconnect it because it is to be used as a remote turn on.
-zook- wrote:It is being used already by the harness.
so what...just attach your amp wire to it and have a nice day.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
wysiwyg wrote:-zook- wrote:It is being used already by the harness.
exactly, just tap into it with a wire tap, or solder that wire with them.
Elemental Designs
Performance.Mobile.Audio.
alexl@edesignaudio.com
Warehouse Manager
If all else fails, just find a 12v constant (lighter comes to mind) and attach the amp remote lead to that, with a switch in between.  It means you'll have to flip a switch every time you start the car, but if you're REALLY lost, it's one course of action.
Even so, you might just take it to a stereo shop if you're having a great deal of difficulty figuring it out.
Try what was mentioned above first though.
Ill just use the blue/white and crimp them all.
