Don't use them.
They get really hot, really fast.
I just installed them today w/ my side-firing 3157 LED bulbs for the front turn signals.
Get the electronic component flashers... James, I highly recommend getting one instead of the load resistors I gave ya (the brass things).
With that said, are the stock turn sig flashers 2 pin or 3 pin (I haven't been able to find mine, but will look this weekend)
um, resistors, use heat to shave off the current, duh they are gonna get hot
The stock flasher is a 5-pin unit.
Machzel08 wrote:um, resistors, use heat to shave off the current, duh they are gonna get hot
See, I knew that part already, but for those folks that don't and try to mount these near something plastic....
5-pin flasher, huh.... oh hell. That's gonna be fun to track one down for LED usage.
I've got two spare ones here... I'll ship ya one you can crack it open and mess around with it
It's bright green, same size as a bosch relay, and mounted on a plastic tab above the gas pedal.
Thanks John
If you're able to come down to HIN, I can pick it up then -- kill two birds
If not, you can shoot me a PM w/ asking price, etc.
Unless..... one for a newer Caddy w/ OEM LED tails will work, since they use incandescent fronts.
Edited 1 time(s). Last edited Tuesday, August 22, 2006 10:17 PM
Dude, you can HAVE it!! I don't need them. I'll bring it with me to HIN...!
Rob, what's the wattage size on those load resistors?
you could just wire a larger one outside of the headlight itself. just use a slightly larger wire.
Desert Tuners
50w 6 ohm.
They are needed to regulate the blinker speed so you don't have "blinkers on crack"
The passenger side is the critical one... W/ the evap tank there, if not mounted properly, it can catch something on fire
that's the only thing I can think of, unless you put them in some sort of case with a heat sink, or go to a larger rated resistor.
do you have a schematic drawn up for this?
Desert Tuners
No schematic. They are preassembled and various LED bubl storefronts carry them (check superbrightleds.com)
I'm working on a bigger heatsink right now until I can get an EL flasher that will work for j's.
Finally, an excuse not to use the blinker
sweet. can't wait to see the setup bro.
Desert Tuners
Well Im thinking i'll just mount these in the bumper far enough away from the plasticy stuff, what you think? I dont wanna melt anything headlight related or otherwise, not again at least, LOL.
Edited 1 time(s). Last edited Friday, August 25, 2006 1:29 AM
As long as they are mounted to metal, away from plastic and the evap tank, shouldn't be any worries.
Where would you mount load resistors in the trunk for LED tails?
Gotta keep on livin', L-I-V-I-N
part # for flasher
Grote p/n 44090 5 pin led flasher
Kardain, thanks. How do you keep them off the carpet, and are the JamStrait resistors any good, or where could I buy some good ones?
the tower should be far enough away from the carpet.
Quik -- what relays were you thinking of? I can test it next weekend (leaving town this weekend)
Kardain, thanks. Another 2 quick questions. The Brake lights wrok fine, but the running lights can barely be seen even at night, and I've obviously got the hyper blink. Are the resistors going to fix these issues? Also, which color wires do I tap with the resistors?
