Put it where there is going to be some air flow on it. Where do you have it mounted?
GIT 'ER DONE!
Are you sure you have the gain set properly?
Use some cooling fans. check the gains and make sure that the ohm load on the amp is correct.
-Will Ong
Don Long wrote:I've got it mounted to the back of the rear seat.
Amp is not going to dissipate heat as well mounted vertically. Mount it flat or try a couple fans.
put the seat down and it is horizontal.....or flat for you ohvrolla
what do u have the amplifier bridged at? Most sony amps cant do much more than stereo x2@2ohms if u have it bridged mono x1@2ohms that'd be your problem.....
Get some 3/4 tubular washers and mount them to you amp on the bottom side, then mount 1 or 2 fans under the amp and hook them to turn on when the amp comes on. Should help
