I have around 850 rms watts now. but im planning on upgrading on of my amps. so then i will have a total of 1200rms what gauge power wire would i need.
right now i have 4 guage power wire going into a block into 2 8 guage outputs.
I was told i need a cap. is this true
Anything above 600 watts or so and I would upgrade to 4 awg into that amplifier.  So just run 4awg into the amp.
With a total of 1200 watts rms, you should be fine with 4awg still, any bigger and i would suggest going up to 0awg.
It also depends on the brand of wire and its strand count.
If its a cheaper brand like Raptor wirirng, and the 4awg is closer to 8 awg, then you want to get a real quality 4awg.
As for the cap. Dont add a cap..say the cap cost $60-80.  invest that money into an optima yellow top and then upgrade your under the hood wiring with the big 3. Or try the big 3 first. see if that helps reduce dimming.
Caps are just small batteries. They rate them in Farads. A $70 cap is usually 1 farad. To put it in perspective. An optima yellow top, or a standard deep cycle, on average is 100 farads or more. (so ive read). For around $100-200
Elemental Designs
Performance.Mobile.Audio.
alexl@edesignaudio.com
Warehouse Manager
alex if u find me a new yellow top for $100 i will be your slave
yellow top or standard deep cycle i said....the deep cycle can usually be had for 100...then more for the yellow top.
Elemental Designs
Warehouse Manager
Yeah yellows retail for around 170. I'm running 1200 watts through my amp, and I'm using a 4ga RF wiring kit. Like Alex said, as long as you use a high-quality or high strand wiring, 4 ga will be fine.
you can get used yellow tops for 100 all day long if you look around
but I am going to be using a marine deep cycle for it's longer standby rating than optima yellow top.  And it's only like 60 bucks.
Well i have street wires wiring right now, thats 4 ga is that ok?
