ok i toke my dash off and everything to paint  but never touched the cluster and @!#$  now after i finished it all the cluster wont light up but like the fliud lights do and the gear light does
now the interiour lights still work but not the cluster
i found   a fuse that was blown  so i replaced it with a 10 amp witch si what it said i should and it blew that  so should i gte a biger one or whats happening?
and also  my head lights on the car   hi beams work but not low beams and i just replaced the  bulds   and still nothin  any ideas  get back guys ty
The fuse keeps blowing because there's probably a short.  Don't replace it with a bigger fuse unless you wanna see stuff melt.  Head lights - check fuses for left and right headlights.  If they are good, you might have a bad switch.
hmm where could there be a short tho  the cluster had no problems before and i never touched it  at all so ya
maybe your car is possed, lol j/k man
check the harnesses going into the clust and that there tight, thats about all i can think of!
Who needs a sig?
www.sinisterimages.com
i  had the ash off aagain and  i tryed to  move the harness thats attaches to the cluster  and the hole time i was pushin it on more and wiggeling it  the cluster never cam on  but then  last nigth  i put another fuse in it and it cam on for 0000.1 second lol  then blew the fuse so i'm guessin it must be a short some where in the line but i dont felel like  doin it right now lol
i got it fixed   the car use to have a  alarm on it  but i toke it out  cuz the the lockin things didnt work right  and i didnt know what i needed to take out for  takin the harness out
so i toke the time and fallowed where all the wires in the harness ran and  toke out all the wires thats the alarm used and now its fixs so in the end the alarm was wired in to the  cluster wires or somthin and was  shorten it out
but w/e its fixed  now  cars cummin alone nicely  starten to look a lil better   the interiour  is almost done  but then i get into the importent stuff
i hope i dont have to many problems with the rest of the @!#$
hmm, wire short, who knew?!?!?
nvm  it works but as soon as i put the dimmer more then half way it blows the fuse again  wtf that makes no sence to me  any one got any idea's
you could have cooked your dimmer switch with the short.  or when you adjust the dimmer, which adjusts voltage, it could be letting something else short out.
