ok here is the thing.. my 02 cavalier sedan just started doin this in the last coulpe of days.... the fuss keeps blowing for my exterior lights... IE just my park lights on each corner and my rear lights.. and my gauges go dark.. my brake light work fine and my head light stay on .. why does this keep blowing?? i mean i don't know whats going on .. i keep replacing the fuss and ever time i turn my head lights on it blows again.. could anyone tell me possible problems?? and how to fix this?? anyone at all?? i need this fix because i can't drive at nite.. my turn signals work also but i still don't know the problem
just riding around in the 4 door cav
Short prolly
Just start checking the wires.  See if something has been rubbing or something.
Might also check the harness for the headlights and see if somehow either side is touching or something.
-Seth
i'm gonna check it out tomorrow during the day time.. thing is the head lights work fine
O, well I meant ur parking lights.  Which ever cause the fuse to blow.
-Seth
man i gotta figure it out.. i unhooked everything.. subs.. cd player.. ege.. crossover.. amps. cap.. leds.. everything and it still does it.. i'm running out of fuses lol.. i'll check in the morning .. thanks seth hopefully this is the problem..  i dont' want to have to trace this, i wouldn't know where to start
um, start up at the parking lights?
ok guys... here is what i found after about an hour of tracing wires every where and tearing my head lights out and about 27 fuses latter...... the terminal for my left rear brake light has some kind of short from the connector to the housing of the bulb causing it to get less power the the other brake lights.. and making my fuse blow.. i checked and checked and triple check and when i took it apart and put another fuse in and turn on my lights.... what do you know.. my lights work again ... so i'm gonna have to find another one.. or a set and just swap them out.. know of anyplaces where i could get them?? i'm new in Lawrencville so i don't know of any J yards yet thanks again for the advice guys.. this is what the Org is for
you might be able to get a bulb housing at autozone or advanced auto parts.
got it.. just waiting on the call back.. to go pick it up and install it
