ok im wondering how u guys are mounting these walls like do u bolt it stright to the body screw or glue cause i got to thinkin about it and it blew my mind cause bolts might vibrate and same with screws and i have no idea about any glues but if some one could help id like that but thanks
if your bolts are heavy enough they arent going anywhere.  also do not go down into the floor in the backseat area.  thats your gas tank. if you build into the trunk you can bolt it into the trunk floor if not you can bolt into the area that slopes up into the trunk
I have L shaped brackets that bolt from the back of the box, to the floor of the trunk. with lock washers, those bolts aren't going to come off on their own.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
cool thnaks for the info helps out alot never really thought about L brackets but thats cool
mine is held in with metal brackets made from angle iron welded together like a roll bar style and then welded to the floor of the trunk by the strut towers it aint goin anywhere lol
