How do I find out my subwoofer displacement so I build a big enough enclosure?
I have:
2x Power Acoustik FUBR-15
3 cu. in. ported per sub
set the example, never let the example set you.
I know some companies have an A: B: C: on the description of their subs like parts-express, but dont know what to measure to find out
does it tell you the requiered length for the port for each sub??? other than that  all you need is
a=length
b=width
c=hight
  so for example , to get 3.0  cubic feet you would go
a=15.5 inches
multiplied by
b=16.75 inches
multiplied by
c=20 inches
devided by
1728=  3.04 cubic feet now remember these would be the inside dimensions of the box  so depending on the mesurements you would use 5/8 mdf or 3/4 mdf with appropriate bracing
dude i already gave you box measurements
no i mean the the subwoofer displacement.  dont you have to add the actual space the subwoofer takes up with the recommended box size?
that my question
well i am unable to find the specs  other than the basics but it should be about .08- .10 cubuc feet as a rough geuss
i agree its not going to change the volume a whole lot.  plus is going to be in a vented or sealed enclosure?
i beg to differ each of my woofers displace over.25 times 4 thats alot
