how exactly do i get the stock 6x9's out of the rear deck? they come out from the top correct? I can't figure out how to get the carpet and the board under it off of the rear deck. any help would be appreciated
you have to take the rear of the back seat out and also remove the side plastic parts then the rear deck will come out to get at the speakers
[IMG]
1. Lower the back seat, and remove the 4 clips that hold the plastic trim pieces to the rear dash.
2. Next, remove the 2 plastic trim pieces. To do this, pull them slightly toward you, and angle them toward the ground. The small clips that hold them in will pop out of place.
3. Pull the rear seat belts through the slots in the back deck, and then pull the slots inward a bit. This will allow the piece of rear deck that is under the sides to come free.
4. Now just start pulling, and jiggling it a bit. You may also need to bend the centre of the dash up slightly, being careful not to crease it. It will eventually slide out.
5. If you are trying to remove the rear speakers, simply push in the little clips that are facing you. You will need to disconnect the speaker wire connection. The factory speakers are held in by 4 screws. Remove those and the factory speakers will pop right out. The Rear Speakers Are 6X9's, but you can either make or buy adapters so you can use a component speaker system.
TEAMFORWARDMOTIN.COM
