Well after realizing I just dont have the space for these 9917s to really shine and realizing I can do much more with less Ive decided to sell the 9917s and tear the wall out. Doing 2 DD9515's off 2 MA HK4000d's and the plan is having the subs stacked with port driver side. Looking to hit a 155 with 1 amp
 Anyone know off hand what the height is back there? I am kinda unsure about if I have the room to fit 2 15's stacked with a proper dance floor and bracing up top.
mine are staggered lemme find you a pic
not thinking there  is enough room to stack on top of each other hope that helps
I see you dont go too close to the top of the wall why is that? Bracing? I was getting some dimensions and were gonna be doing 2x2 square tubing for the bracing ripping out all interior panels back there and welding it to the sheet metal instead of doing 2x4s. Hoping to save a bit of room doing that and have a much stronger base. Hmm I wanna do 160s
you want to do 155 with 1 amp but your going to use 2 hk4000ds?
thats not going to be easy with 3000 watt's, what are you going to tune it to? i just got my sub's back and im going for the loudest non-walled J but ill be happy with a 150 and some change (sealed up at the dash)
you should have more than enough room for two 9515s.  That wall in mine is like 13.5 cubes external . I would not go that big for the DDs.  When i redo mine they will get 4 to 4.5  tops. I have two in this same wall now and I think they would benefit from a smaller box . .
Id like to but I realize its not very easy. Plans are eventually either 8 20.1's so 2 strapped per coil or 8 MA HK3000Ds. Also seeing how long it would take for me to have the funds of doing 8 40.1's
im going to get a price on some Stetson 7KD tomorrow ill let you know, so far they look like a good amp. its probley like all the other 7-8000 watt amps that came out in the past few months
160's, man that's a lot of crap in a little car, lol. better be putting some air ride on there to help with the weight, lol.
I'd like to be doing 155+ myself, If i can hit that, then i'll stop changing stuff for awhile, lol
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
A 155 is my goal too. I believe I have enough power and woofer to do it.  just gotta get the build strong enough.
or do you mean get the build started?
hahhahahaha you got jokes.  lol.  something like that.  .
haha i have my sub's and ready to get the amps but im remodlen my house so times kinda short and with what i plan on doing is going to take a few days.
hey wysiwg what are you running for an amp again? and are you using a battery in the tyrunk and a bigger alternator?
megatron wrote:hey wysiwg what are you running for an amp again? and are you using a battery in the tyrunk and a bigger alternator?
this isn't my topic, but what the hey..
two orion 2500D's.
Sitting on stock alt and dual batts, but will be upgraded before i start beatin it up.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
we should all get together one weekend and build walls for our cars.  no more procrastination, blah, let's just get it done.
paying for beer and food!
155s aint loud enough
  Still trying to figure out if its worth messing with the cavalier for a pure spl car or just getting another car and maybe doing a small system in the cavalier. Oh the idears
the cav can get loud when walled.  it hink you should ahev stuck with the 9917s and built into the trunk some. i bet it would have done alot better.
I <3 the 9917s but I couldnt get them stacked. Pretty sure we found a way to stack the 9515s in the cavalier. I just wanna get a cavalier above 160
good luck when i get home tonight ill post pics of what a low 150 over prolonged time will do to your dash it aint pretty.
what battery are you planning on using?....btw is a kinetic a good brand?
set the example, never let the example set you.
Oh dear looks like more equipment may be purchased in a few months. 400ft of wire
, nsb90, andddddddddddddddddd
 4 40.1s. Im taking this damn 160.
are you using the 4 9515s?
bmxbikes h wrote:Oh dear looks like more equipment may be purchased in a few months. 400ft of wire
I have 2 200' spools of 4459 strand count OFC with your name on it.
 Blue or silver. Not that crappy aluminum clad crap.
Let me know if you want a price.
Elemental Designs
Performance.Mobile.Audio.
alexl@edesignaudio.com
Warehouse Manager
