Does anybody know a good way in which to do this?? I am trying to fish my power door lock and window wires through the rubber into my doors and vice versa. I have heard of using a wire coat hanger but was just wondering if anybody has found an easy way.
pop the rubber off both jams run it thorugh by hand then put the rubber insulators back on the jams. easiest way possible. ive never had luck with fishing them.
alright i will give that a try and see how it works. Thanks
Ya, that's the best way right there. Saves you tons of time... I did it the long way with a coat hanger the 1st time, and popped it off the second. Way easier.
I usually pop the rubber thing off and tape the wires I want to run through to a screwdriver.  Push the screwdriver through, take off the tape and pull the screwdriver out.
thats what i do, pop the rubbers, then tape to a screwdriver, just saves the hassle of fishing through and the wires getting tangled
if you want to save some time you can just pop one side of the rubber off. thats what i did when i ran my speaker wire to my doors. it worked pretty good and saved me having to pop back on both sides.
1997 RedR - ZedR
yea i popped the rubber off and ran it through with a coat hanger and it went pretty smooth. Thanks
