Ok so for Christmas i got a Ractive Shifter knob (auto) I know how to install it thats not a problem but what is a problem is the ETS . I have a button on the side of the stock knob which controls the on/off mode for the ETS So when i remove the knob can i do one or both of the below?
1. Re-wire the original switch to somewhere else on the dash/center console.
2. Join the wires together to make a constant loop which if im correct will mean the ETS will stay on constantly which isn't a problem?
(99 - Sunfire - Red - 2200)(95 - Cavalier z24 - Purple - 2.3 quad four)
yea a simple toggle switch some where should work fine,
or you can join wire it permanitly on and do what us cavalier owners do to dissable it... pull the ebrake up a notch
1997 RedR - ZedR
if it has a button for ets, connect it to the ets switch wires, you will jsut have to hit the switch twice for every action. so on-off to disable. on-off to enable.
Ok thanks guys, i just didnt want to go and remove it then find that i cant re-wire it somewhere else. Thought it best to check
Anyway thanks for the help.
why didnt chevy wire in a traction control switch?
i mean it's great and all to have ets but some times it gets annoying
