I have a crimestopper CS-865.RKE.II for keyless entry and i have a free channel.. My plans are to be able to turn on my underglow with one of the channels.. I know there will have to be a relay somewhere but I don't know how to hook it up.. I want to be able to hit the button and the neon will come on.. then i hit it again and it turns off.. Is this possible?
http://www.jbodytuner.com
^^ The real jbody store and forums!!!!!
depends... will the channel stay on when you hit the button or is it momentary?
if the channel will stay on then you can do it with a normal relay, if not you will need a latching relay that you can latch and unlatch with the same channels signal.
1997 RedR - ZedR
i dont know.. how can i check? I'm guessing it is momentary. i will take a test light to it tonight but i think it is a negative channel.. so will i just hook the end of the testlight to possive and other to that wire?
o i got it... lol sorry.. but there was an issue.
http://www.the12volt.com/12voltimages/latchonoffspnd.gif
i used that but when i hooked everything up, i started burning out leds in my switches... so i took it off the switch and it is on my remote only and it works
