Sup guys, today i go to turn on my head lights and they are really dim...my drls dont work and when i turn on my high beam it gets bright but the pass side head light turns off! i have not had a chance to check it but before this i was driving around with my high beams on becuase my low beam was out on my driver side. (it was not the bulb i checked everything it NOW turns on but very dim!) this is a weird problem could it be the switch? tomorrow im gonna check the bulb and ill see whats going on.....
check the relay for your headlights. possibly change the headlight bulbs. Go to a napa and get the phillips headlights they are bright and only 10 dollars for a pair.
thanks for the response, but i had some downtime at work today so i decided to take a look at it....turns out there were about 6 wires all corroded and wet in the harness next to the radiator. I rewired it up and its all good now, so if any one has any weird headlight problems check the harness!! What i also realized while testing and everything is if the switch was bad both headlights would be out not just one....so check the harness!!
