amp for type r's - Audio & Electronics Forum
well just decided to upgrade the subs from 2 mtx roadthunder 10's to 2 alpine type r 10's. so now i'm in the conundrum of not having an amp powerful enough to power them. the subs are DVC 4 ohm and i am looking for a 1 channel amp that puts out around 1000 watts RMS at 1 ohm without breaking the bank. any ideas would be appreciated.
"I did it because I wanted to see what it would look like. You should be greatful that I even told you that it would look good. If your to dumb to use photoshop and change the color of your own car then you don't need to see it changed. I'm not going to give my work away. I'll sell the pic to you though for $15."-Adam Kalin
^^JBO is about not being that guy
How much is are you willing to pay before "breaking the bank"?
up to 300
i have the rockford fosgate p1000 amp and it pushes out 1000 watts rms at one 1ohm. its a good amp IMO, i have it powering 2 rockford p3s (12") and doing it WELL.. its a little more then 300 but well worth it
I forgot about the 1ohm part..lol. well umm.... the MA audio HK401sx on woofersect is 100 bucks more but has 1200watts rms @1ohm. might be worth saving up for?
0cavZ24: the alpine wont work as i bought d4 woofers, thanks tho
grimez: how much did the p1000 run you?
01cavZ24 wrote:I forgot about the 1ohm part..lol. well umm.... the MA audio HK401sx on woofersect is 100 bucks more but has 1200watts rms @1ohm. might be worth saving up for?
Looooooove me some hk401sx's, running 2 of them.
what do you guys think about
this? i can afford one right now and probably a second one in a couple months...
I haven't heard much about kenwoods amps but if your just wanting something thats going to put power to the subs, its a good deal, I would suggest saving money for the MA hk401sx if you want something that will make those subs work hehe
grimez wrote:i have the rockford fosgate p1000 amp and it pushes out 1000 watts rms at one 1ohm. its a good amp IMO, i have it powering 2 rockford p3s (12") and doing it WELL.. its a little more then 300 but well worth it
that rockford amp is no joke.....its a lil expensive but its a beast! most birth sheets i have seen are all over 1200 watts rms and it will do it with no problem all the time. I have installed a lot of these and some people come back complaining its to loud and return it....go figure
  if i was you i would save for a couple weeks, you wont regret it....or even a diff amp just spend your money ONE time and you will be happy!
Ok well I'm replaing my mtx 6000 10" subs tomorrow for the type R 1022D's.  I'm running with an MTX 6500D.  I have  sealed enclosure with 1ft vol.  I will be rebuilding th boxes eventually but tomorow I am simply swapping the subs.  I'll let you know how it goes.
i have a Planet Audio VX4002 2 channel 800 watts amp i am selling... i don't know if it's 1 ohm stable or not, but i used that thing to power 2 subs and it did a great job doing just that.
the rockford p1000-1bd amp cost me about $400 brand new. im also gonna take video of my set up and put it on youtube for everyone to see!
is this a good deal? i can get it for 199 locally and its got sufficient power. i just really dont know how high quality lanzar amps are
If you are looking for a 1 ohm mono amp...the lanzar amp is definately not it. Its only 2 ohm stable
01cavZ24 wrote:If you are looking for a 1 ohm mono amp...the lanzar amp is definately not it. Its only 2 ohm stable
well obviously not but it is 2 ohm stable in stereo, an it puts out a lot of power that way
that amp looks pretty nice. but id have to use it in 4 ohm. which is fine. what i was implying was that i would be willing to go for a 2 channel amp that puts out around 500W RMS at 2 ohms
the subs you have can each be wired down to 2 ohms and run to the amp. the amp has 2 sets of terminals that accept 2ohm stable subs. if you set it up that way, you will still see a 2ohm load....if i remember right
01cavZ24 wrote:the subs you have can each be wired down to 2 ohms and run to the amp. the amp has 2 sets of terminals that accept 2ohm stable subs. if you set it up that way, you will still see a 2ohm load....if i remember right
that amp would see a one ohm load. those 2 sets of terminals are wired in parallel to each other.
I was told they would see a 2ohm load.... someone lied to me haha
