01 Sunfire GT rear speakers - Audio & Electronics Forum
Tuesday, April 21, 2009 8:24 PM
According to Jbody's sticky thread, I should have 6x9" speakers in the rear, however, I've been to several car audio websites and they stated that 6x8" and 6x3/4".
Which aftermarket rear speaker size would fit my 2001 sunfire gt?
Thank you.
Re: 01 Sunfire GT rear speakers
Tuesday, April 21, 2009 8:47 PM
6x9 is a common aftermarket speaker size and it will fit your car like that stock one does, as the stock one is a 6x9 aswell.
1/4 Mile ET 15.2579 at 89.97mph
Wednesday, April 22, 2009 12:53 AM
I should also mention that the car is equipped with a Monsoon stereo system - many car audio websites state that I cannot install certain 6x9 speakers because of the Monsoon system. Is this true? or will any 6x9 work?
Wednesday, April 22, 2009 7:57 AM
Doesn't matter about the monsoon, all they do is send a signal to the tweeter and a separate signal to the woofer. Just about any 6x9 will work, however, you might have to do a little fabricating depending on the 6x9. You may have to mount it from the bottom or alter the plastic bezel the 6x9 sits in. Check Lenko's and my stickies for info on how to wire it up.
Wednesday, April 22, 2009 1:39 PM
Could you please show me the link? I can't find it in the sticky.
Thanks
Wednesday, April 22, 2009 4:10 PM
Radio Wiring
Off the radio harness:
Left front +: Tan wire, pin A8 (to E2 on amplifier)
Left front -: Gray, pin A9 (E3)
Right front +: Light Green, pin B11 (F1)
Right front -: Dark Green, pin B10 (E1)
Left rear +: Brown, pin B8 (E6)
Left rear -: Yellow, pin B9 (E7)
Right rear +: Dark Blue, pin A11 (E5)
Right rear -: Light Blue, pin A10 (E4)
On the amplifier harness:
(inputs are as noted above), outputs:
Left front tweeter +: Black wire, pin E13
Left front tweeter -: Yellow, pin E14
Left front speaker +: Dark blue, pin E15
Left front tweeter -: Light blue, pin E16
Right front tweeter +: Light green, pin F2
Right front tweeter -: Purple, pin F3
Right front speaker +: Orange, pin F7
Right front speaker -: Dark green, pin F6
Left rear tweeter +: Tan, pin F15
Left rear tweeter -: White, pin F16
Left rear subwoofer +: Dark blue/white, pin F5
Left rear subwoofer -: Light green/black, pin F4
Right rear tweeter +: Red, pin F14
Right rear tweeter -: Tan, pin F13
Right rear subwoofer +: Light blue/black, pin F11
Right rear subwoofer -: Dark green, pin F10
Use the rear woofer sets and you'll be golden.
Friday, September 04, 2009 2:16 PM
I just finished my eco swap and the class 2 wiring is new to me. I have 6X9 polk audio mmc690 and they came with the crossover but im wondering if I can wire them up using the tweeter, woofer sets or would i be better off using the woofer sets and the crossover for the speakers?
People can't learn common sense. You're born with it. Either you have it or you just don't!
Monday, September 07, 2009 3:54 PM
Bump!
I'm getting horrible feedback whether i wire them up trying to separate the mids/highs and woofer or if I try to power them off the woofer and use the crossover. btw being a cavi my tweeters are diff colors but it always been different from the suns on all the wiring. Any suggestions and/or input would be of great help.
Monday, March 21, 2011 8:49 AM
You could also do what I did and hook up a pair of 6x9's to the woofer wires and a pair of 5'1/2's to the tweeter wires and have 4 speakers in the rear deck
