speaker mounting - Audio & Electronics Forum
speaker mounting
Monday, December 13, 2010 12:04 PM
is it better to mount the speaker inside the door in the stock place or is it better to mount it in the door panel??
Re: speaker mounting
Monday, December 13, 2010 5:55 PM
NEVER mount to a flimsy piece of plastic like the door panel. If you're upgrading, either make your own, or find someone who will make you a decent bracket out of MDF. Then bolt or screw that setup TIGHT to the metal inside the door. It's totally worth it. All speakers need a clean, flush, SOLID surface to mount to.
"In Oldskool we trust"
Monday, December 13, 2010 6:01 PM
What Ryan said.
"You really need to staple your face shut"-THE Joey Baggs.
Monday, December 13, 2010 8:28 PM
Well.... I wouldn't say never
Monday, December 13, 2010 10:00 PM
wanna go through the explanation of how you would mount the speaker on the outside of the door panel properly, or just assume he doesn't want to do that? lol
Tuesday, December 14, 2010 5:14 AM
JLAudioCavalier wrote:wanna go through the explanation of how you would mount the speaker on the outside of the door panel properly, or just assume he doesn't want to do that? lol
make a simple wooden ring on the backside of the doorpanel. attach to door panel. u can predrill your holes. now make a similar type ring that is attached to the metal door panel screw it do the metal with hole for screws offset from your other trim panel. now you can put the door panel on the door and your door panel rind and your trim ring attached to the door meat up and cause a seal. now you screw the speaker to the doorpanel (thru both wood mounting rings) now your speaker is attached to the door panel and at the same time tight, secure and sealed up to the door. this can be done to show off the speaker, or if your dealing with a speaker that is just to deep to use a baffle and fit behind the door.
Tuesday, December 14, 2010 2:15 PM
w3rd. i'll be doing this soon.....
