gauges - Audio & Electronics Forum
gauges
Sunday, August 12, 2012 10:56 AM
Hey all, I have a 2000 chevy cavalier 2.2l with a 3spd (sadly)
I tried looking for some information on gauge wiring for a cavalier and which sensors I can attain easily and which I would have to do some modifications for.
I'm looking for a tach , oil pressure and air/fuel ratio. I'm very meticulous about this car anything goes wrong I want to know before it happens. Thanks for all who can help!
Re: gauges
Sunday, August 12, 2012 3:50 PM
you can swap your gauge cluster for any cluster that has a tach, thats pretty easy, air fuel ratio will either require a wideband kit with a sensor or a narrowband gauge that can be wired into the stock front O2 sensor. Oil pressure is pretty simple too, just get a gauge with electric sender and a tee fitting to tee in with your stock dummy light sensor. and oil pressure is/will be less of an issue with your 2.2 vs if you had a LD9 or Ecotec
Re: gauges
Thursday, August 30, 2012 7:42 PM
thanks man, things to do during next summer.
