Hi, I just got done installing my 880 Hid fog light kit and my 9007-2 hid headlight kit. Fog lights and hi beams work fine, but the low beam HID will not power on. These are the HIDs with the HID low beam and then a regular Hi beam bulb next to it. Any help would be greatly depreciated.
<img src="http://www.v6z24.com/jbodyforum/images/signatures/cavalier3400z.jpg" width="319" height="199"/>
Make sure you have the polarity correct going into the ballast. If reversed it wont operate.
Have a nice day.
Switch the 3 wires in the blue headlight clip. Worked for me.
Proud member since 99
I believe the wires match up to my HID plug fine.
Hight, ground, low. in that order if you are looking at it. I believe I found the issue. Mine are direct plug in. When I used a meter the low beam puts out 7 volts, where as the high puts out 13 volts. I believe it does not supply enough to ignite the HID. I am going to wire in a Relay for the low beams tomorrow. That is really odd that GM would run such low voltage to the low beam headlight.  I checked with two other cars I have and had the same issue.  When I jumped them to the battery the HID lit perfectly.
Here are some pictures. I was able to install the HIDs without Disabling the DRLS. I also had to wire the relays different the the HID Relay Harness Diagram that is on this site.
Here is how I wired it:
87 - Ballast +
30- Battery +
86- Factory Headlight Ground -
85- Factory Headlight Low Beam Power +
I grounded the Negative (-) Ballast Wire to the car.
The Diagram Showed:
87- Ballast +
30- Battery +
86- Battery +
85- Factory Headlight Ground -
Stock:
HID Foglights 10,000k:
DRL:
DRL with Parking Lights:
HID 10,000k:
High Beam:
I kept all the stock functions while still being able to use HID headlights and Fog lights.
