Thunder vs. Rockford - Audio & Electronics Forum
Wednesday, February 23, 2005 11:03 AM
For all you that think that Rockford Fosgate is better then MTX take a look. Clicky Clicky.
Travis Nobert
Travis Enterprise
Come on down to Evolution Audio in Edmonton Alberta, and I can HOOK YOU UP.
Re: Thunder vs. Rockford
Wednesday, February 23, 2005 11:54 AM
I've always preffered MTX. I'm not very well versed in their subs, but their amps kick the llama's as$. I use an Infinity sub, and I like it pretty well, so I'm not complaining.
______________________________________
Hell hath no fury like a pissed off balloon animal.
Wednesday, February 23, 2005 12:02 PM
Or you could just get kickers.......
*Waits for someone to diss kickers....*shrugs
Wednesday, February 23, 2005 12:12 PM
See, you have to have money for that.
"Sup, G?"
"Aren't you white?"
"Only on the outside, craka."
Wednesday, February 23, 2005 12:13 PM
i knew rockford amps were @!#$ when i went and blew 2 Power 1001BD's in 2 weeks.... when i opened it up, it was those small FET's they show in that article that were blown...
Wednesday, February 23, 2005 12:21 PM
As said above, a couple years ago I tried a Kicker amp and have been very happy with the three I've had.
-Chris
Wednesday, February 23, 2005 12:26 PM
college freshman between jobs, kicker is out of the question.
"Sup, G?"
"Aren't you white?"
Wednesday, February 23, 2005 12:29 PM
1 kicker is cheaper than 3 mtx/fozzy's hint hint. Buy once, replace never.
Wednesday, February 23, 2005 1:20 PM
my sub only needs one mtx. I got it for $80 off ebay brand new
"Sup, G?"
"Aren't you white?"
Thursday, February 24, 2005 4:59 AM
that site really isnt telling you much. max temperature for one amp may not be the same as max temp for another amp. so u really can't compare them. diffrent power supplies can still put out clean power,i beleive both compans are involved with the new wattage ratings system. its really not that much of a deal. ive seen both companies have blown products and i still see allot of guys running both types of equipment on stage at the world finals in most orginasations picking up their trophy's. if u want to find out wich is better it would be allot more beleivable if the test was conducted by an impartial panel, not by mtx.
Thursday, February 24, 2005 6:14 AM
throw in the ohm load each amp is seeing too. If an amp is design to run a two ohm load and you give it an 8 ohm load, I bet it runs really cool. and opening up the gains will do the same thing. Clever advertising.
Thursday, February 24, 2005 12:48 PM
It took me a minute to find the flaw in that ad, but anyways Rockford is better
250 rockford watts = 1000 other brand watts
Thursday, February 24, 2005 12:57 PM
sndsgood is right...
its not like mtx is going to say rockford is better
its too biased
Thursday, February 24, 2005 1:09 PM
Facts:
Look at this pic, the paper is for a model 301s
This is from RF webby
Channels 2
Per channel power 75 W X 2 @ 4 Ohms RMS
150 W X 2 @ 2 Ohms RMS
300 W X 1 @ 4 Ohms Bridged RMS
Total power 300 Watts
900 Watts Peak/Max
Paper said power ran at ( all channel at full power) is 309 - right
If it were wired differently you could get the full 900 peak not 300
Such as 300w@1 @4ohms
More
1st they compare the Punch 201s to the Thunder 202
Lets see here..
Punch 201s
50 W X 2 @ 4 Ohms RMS
100 W X 2 @ 2 Ohms RMS
200 W X 1 @ 4 Ohms Bridged RMS
Total power 200 Watts 600 Watts Peak/Max
Thunder202
All RMS
2 Ohm Load 75 w x 2
4 Ohm Load 37.5 w x 2
Bridged 4 Ohm Load 150 w
Then
Road Thunder 251D Class-D Amplifier to a Punch 301m
1st of all the 251D is a class D amp of course the circuitry is going to be bigger than a non class D amp such as the Punch 301m
They should at least compare amps that are the same level and close to the same output!!
<img src=http://www.mclonedogmcwad.com/sig3.jpg>
Please visit <a href="http://www.abstractcarclub.com">Abstract car club</a> & <a href="http://www.mclonedogmcwad.com">mclonedogmcwad.com</a>
Friday, February 25, 2005 4:52 AM
I bet htat amp does 900 MAX watts. again clever adviertising.
Friday, February 25, 2005 7:17 AM
Have you heard about CEA-2006? They test all the amps that are coming out at a continous power rating under different loads. When your looking for a new amp you might want to check the CEA rating.
Friday, February 25, 2005 11:20 AM
not all amps are cea rated. US Amps. Orion PPI helix brax mcintosh are all not CEA rated and would spank the ass off almost all of the ones who do that
Friday, February 25, 2005 6:59 PM
okay, lest stop this topic, both amps are good, but it all comes down to personal perference in the end. am i right? what the power ratting is for the amps is imiteral, it is wheather or not it will work for that person's application. i started this post and after mclonedogmcwad increased the photo for me, i realize i was wrong to post this topic.
Travis Nobert
Travis Enterprise
