Headlight /Blinker switch wut happen??? - Audio & Electronics Forum
Thursday, March 17, 2005 8:10 AM
well my headlights didnt stay on.. ya ya ya so i replaced the headlight i had a problem with this little pin on it whenever it hit metal the horn would go on.. anyway i installed the switch everything works fine.. but my horn will only go on if i have the wheel going perfectly straight ie: if i push horn when turning or anything other then straight it wont work??? theres this pin on the switch it didnt look like it had any slot to fit into so i have no idea maybe someone installed the switch and knows wut happen? thanx
Re: Headlight /Blinker switch wut happen???
Thursday, March 17, 2005 11:58 AM
That "pin" is how the horn button voltage gets to the switch... then down the wiring harness to the relay then to the horn itself....
You don't have the turn signal switch lined up quite right... disconnect your battery (so the horn isn't honking when you do it) then pull the switch out and re-install in.. make sure it sits in the right spot.
...j
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
