OK GUYS ITS GETTIGN CLOSE TO TIME FOR THE REFLASH TO BE OUT. THE ONLY PROBLEM IM RUNNING INTO IS THAT I CANT GET THE PART NUMBER FOR THE RIGHT MAP SENSOR.
SO IF SOMONE HAD THE KIT
04 BLACK FIRE COULD YOU LOOK ON YOUR KTI AND TAKE A PIC OF THE MAP SENSOR THAT CAME WITH IT. ITS ON THE LEFT SIDE NEAR WHERE THE RADIATOR HOSE IS.
I HAVE SEEN THE ONE ON AN ION REDLINE AND WHEN I OOK IT UP IN THE PARTS CATALOG ITS IS NOT AVAILABLE FOR PURCHASE.
THIS IS WHATS MAKING ME WONDER.
ANY INSIGHT IS APPRECIATED
*************Yea i spell liek wrong get over it*****************
** If i write in caps its cause im @ work and i can only write in caps cause the keyboard is a retarded CAPS only keyboard.**
that sucks
i wonder if because it is a dual sensor , as to why they cant find it
i know its a bosch sensor
yes, this info would be greatly appreciated!!
we love you whoever out there posts this info
"Growing old is mandatory. Growing up? Definitely optional."
what about the saab map sensor
I want to purchase a map sensor but the part number i have doesnt work.
There will be some custom fitment to get the sensor to fit if we can even get our hands on a map sensor, and dealing with a plastic intake mani is another issue.
THE SAAB MAP SENOSR IS COMLPETELY DIFFERENT........
dang.
Now I am wondering if the gm charger map sensor will even work.
would it be possible to have a company such as bosch to make a map sensor for us?
of course it would cost a lot of money and would require a good amount of people initially wanting it tho.
by gm charger i mean redline/SS charger.
I'm sure if we can find the 2.2L gm charger sensor we should be good to go.
Its the stock Cobalt 2.0 sensor.
sig not found
Are you sure about that?
also I am unsure as to how to buy it. Is it a separate part number from the cahrger itself?
the only # on the sensor is Bosch not GM
0 261 230 042
sig not found
hmm, maybe we can buy it from bosch then?
i'll give them a call.
hey justin , bring your saab manifold over
20 bux says you can order the cobalt ss map sensor @ schucks
ok, I tried calling bosch. They said I had to order it from NAPA or something. It was not in their books and they said they could not order it.
Where is schucks??
that's the same as Checker here Brandon
Desert Tuners
