I have a 91 cavalier with the 2.2. Im upgrading the to a 94 with roller rockers and port and polish. Im having a custom supercharger kit made for my car. I will be using the m62. I was wondering what other mods i should do while the engine is beign worked on? I want to strengthen the engine up. Any info apreciated. THANKS
what are you planning on running for boost?? stock 6psi or 8 or 10 or or or. need more info on your plans. also what do you plan to do on the injection front?? fuel management etc etc etc. your stock internals will take some punishment but all is for naught if your fuel mix isn't good.
no he's correct in roller rockers.
What engine does he have?
i plan on running stock psi. Then later on upgrade to higher boost.  As far as the fuel as of right know i no im getting bigger injectors and a fpr. Im also converting it from tbi to mpfi.
on the 94 it would either be the 2.0L OHC, 2.2L OHV, or 3.1L OHV motors. Since it's a cav it will be either of the OHV motors and he will be swapping to roller rockers.
5K PB: 24:50
10K PB: 54:26
Also i am worried about my auto tranny. Will it be ok? If not what can i do to make it stronger?
The autos can take a beating, except the pump seals like to go pretty easy. But other than that, you can get a stall convertor and get the car to launch pretty good. Look up YANK convertors, they have several different stall limits available.
Failure is not failure if you learn from it
02turbo wrote:The autos can take a beating, except the pump seals like to go pretty easy. But other than that, you can get a stall convertor and get the car to launch pretty good. Look up YANK convertors, they have several different stall limits available.
Those cost a bit. wich one would fit? i went into the fwd section. I was also told i could use a 3400 trq converter. THANKS for the info.
This is my other thread i made on v6z24. it was updated with pics of the supercharger.
P.S. i like the response better here then there. More positive over here.
