ok j's
I'm thinkin about doing a turbo set up now, I just wanna push maybe 5 or 6 psi boost i'm not lookin for that many hp, I just wanna basic turbo set up and whoever knows about turbo set up for a 2.2L ohv,
could you guys pleased help me out J's
What do I need for my turbo set up for 2.2L ohv
I need a List of things
thanx! J's
Redd214 wrote:The GENERAL list for a turbo'd J is this:
Turbo (generally a T3 or T3/T4 will do)
Wastegate (Internal or external)
Manifold
Turbo downpipe Flange
Bolts for turbo and downpipe flange
Downpipe
Braided oil lines with fittings
2.5" Pipe for charge pipes
Connectors and clamps for pipes
BOV and flange
FMU (I'd go cartech adjustable personally)
Bigger Injectors (if you plan to run over 6lbs of boost)
Inline/In tank pump
Boost controller (I'd go Greddy Profec)
MSD-DIS 2 (To turn back timing if you want anything over 6bs really)
TB Plenum
Lots of misc vaccum hose
Rubber Fuel lines for FPR
Oil and oil filter (for the obvious reason)
Gaskets
Gasket sealer
Air filter
Intercooler (optional, but worth it)
Some spare metal brackets for custom mounting the Intercooler
Misc bolts (self tapping), and Nut/bolt combos
Gauge pod
Boost Gauge, EGT gauge (optional but smart to have one)
(If you have a profec boost controller the boost gauge is unnecessary as its built in)
Tools:
A good toolset capable of taking the manifold off
Knife for mild cutting
Sawzall if you plan to cut your own charge pipes
File (in case you need to cut anything and don't want a sharp edge)
Dremel tool (You never know when you need to make room for things, although a good blade and a file will do the same job, but slower)
Drill (To mount your I/C and tap your firewall bolts)
Wire cutters/splicers
Oil Catch Pan
This was in one of the FAQ's up top. I'd read through a few of those, ask if you have any questions.
also for the 95-97 you gotta come up with some way to add more fuel. i was told that up to 6 psi you don't need to worry about adding more fuel but i'm not to sure about that.
http://www.helpelijah.com
it's about 5 or 6 psi you need larger injectors... I have a large fuel pump and an fmu so it helps a little...
if you need im me and I will give you my number...
horsepower is how hard you hit the wall, Torque is how far you push the wall with you
