Just wondering what cams you guys are running with boost... im not looking to go with the secret cam swap or what ever that is... more along the lines of what lift and duration are you guys using? i want to go as much as i can for boost any way (i know you dont want much over lap because of the boost) but i am building up then engine and thought i might as well go to some new cams while im at it
The First Twin Charged jbody
blue car (R.I.P) - 240whp @7psi..
silver car - 305whp 315lbs.tq @15psi (91 Octane) or 420whp & 425lbs.TQ @20psi (94 octane+Alcohol Injection)
All dynos run on a Mustang dyno
I know they are expensive but I have a set of custom ground cams from JBP....
For lift and duration... they have a higher lift than H.O cams and a higher duration than W41 cams.
After tweaking my timing, I got a lot of low end power back.... on a stock tune the car was garbage under 3000 rpm's....
You looking to do up some cams in the twincharged setup?
-Chris-
-Sweetness-
-Turbocharged-
SweetnessGT wrote:I know they are expensive but I have a set of custom ground cams from JBP....
-Chris-
Yea i wont be using the stock tune for them... and help the Twin charged engine is being torn down and built back up ... there are a few more surprises coming (not engine related) for the Twin charged vehica but i wont say any thing till its all done
Do you remember the specs on your cams? as JBP was where i had planed to get them from
I have some decent RaceTech custom grind cams sitting around I would be looking to let go for cheap as hell. (Chris/ Sweetness) knows the shop owner Joe from whom these came from !! (MOre aggressive then the Hybrid/Secret cam swap, but not quite as lopy/ a high lift as the W41 or Ho cams, BUT they are quite decent. PM me if you want to know more !!! (decent idle, and they run flawlessly without sacrificing much low end as well !!)
My Cav
I give up...
Short Hand wrote:I have some decent RaceTech custom grind cams sitting around I would be looking to let go for cheap as hell. (Chris/ Sweetness) knows the shop owner Joe from whom these came from !! (MOre aggressive then the Hybrid/Secret cam swap, but not quite as lopy/ a high lift as the W41 or Ho cams, BUT they are quite decent. PM me if you want to know more !!! (decent idle, and they run flawlessly without sacrificing much low end as well !!)
what is your email? I am interested in racetech cams!!!!!!!!!!!!!!!!
Shawn Coleman
I have been emailing different people for the JBP and RaceTech's cam specs with no replies. Maybe we should rename them to the secret cam's LOL!!
Jason
99 Z24
157hp/171tq
wheres my boost??
How would the HO cams work with boost?
2000 Z24 5spd header & catback for now.
well i think im going to get a custom grind done from JBP ...
Josh F wrote: (i know you dont want much over lap because of the boost)
Misinformed.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
-Chris-
Where can one find proof of what JBP cams can do, JBP vs stock?
Skilz10179 wrote:Josh F wrote: (i know you dont want much over lap because of the boost)
Misinformed.
and how am i miss informed? tell me why a big over lap is good with boost? your forcing the air into the cyl any way .. so all your going to be doing with a big over lap is forcing it in and its going to be pushed out as well... there for making it pointless you wont loose any thing from it but no much of a point to it
Race Tech Custom Grind Cams. (Specs given to me)
-Orig these puppies went for 700 to 850 $ new.
-Intake Cam: Duration @ .050 - Int. 216 - Lobe Lift .380
-Exhaust Cam: Duration @ .050 - Exh. 206 - Lobe Lift .365
http://img188.imageshack.us/img188/666/00003989sp.jpg
IF you ask me, thats a friggin dam decent cam.
My Cav
I give up...
SweetnessGT wrote:Skilz10179 wrote:SweetnessGT wrote:I know they are expensive but I have a set of custom ground cams from JBP....
-Chris-
Exactly where they can find proof what H.O cams can do, H.O vs stock.
Nowhere.
-Chris-
H.O. cams, who said anything about H.O. cams? Oh wait, i get it. Since i happen to be using modded H.O. cams in my motor you're attempting to call me out just because i questioned JBP cams. Pretty clever.
As for proof of the H.O. cams vs stock, John Mackleer actually dynoed them and made about 41whp over stock @ 6 psi without even raising the rev limiter. Also anyone who has ever seen Karo's car, Brandon Fetter's car or my car perform has seen proof.
Back to the real topic, where can someone see the results of the JBP cams or are you just suggesting them because you have them?
Jeremy,
Actually I said that because in all honesty 90% of J-body mods are un-dyno'd... all we can go on is member feedback. He asked what we're running for boost - I told him. Unfortunately I have a custom grind so there is nobody else to ask to dyno stock for stock with these cams other than myself, and of course my engine isn't even remotely close to stock to get a comparison.
I'm not suggesting my cams because I have them, I'm suggesting a custom grind that will match his setup properly. Yeah I know H.O cams yield gains, but a properly matched cam is ideal.
So - other than Mev's N/A dyno comparisons on his cams (showing up to 24 whp gained over stock, seen it with my own eyes), I don't know of a single person personally who's done a comparison yet. My cam specs are more aggressive than H.O cams and more aggressive than W41 cams in different aspects, so I'm personally curious as to what they'd yield over stock but I am unable to give you a comparison.
I'm not trying to be overly clever. Not many people toss JUST cams in to upgrade an LD9... since you have it apart you might as well improve other areas of the engine. I guess if somebody needed a cam spec close to mine and Mev had it ground and they put it in as their only upgrade we'd get an answer... until then all I can say is these are a lot different than stock cams. Maybe one day I'll get a ride in a H.O Cammed car for comparison.
-Chris-
-Sweetness-
-Turbocharged-
*owned*
No, not really owned. I'm just being honest. I have no basis for comparison to offer him or anybody else, sadly. *shrugs*
Not much more I can say about the matter other than good luck to Josh finding what he needs.
-Chris-
-Sweetness-
-Turbocharged-
actually,they have a dyno on their website. 26whp gain from stock.... i got them in my car and gained 24whp, only 2hp off.
dyno sheet
Josh F wrote:Skilz10179 wrote:Josh F wrote: (i know you dont want much over lap because of the boost)
Misinformed.
I must have missed this post, sorry.
Bigger over lap not good with boost or not good with turbocharged motors??? There is a big difference. Turbocharged motors might not like the lengthened duration but a supercharged motor might.
Cams for a turbocharged motor will work better with a shorter duration simply for the fact they have an extremely restrictive exhaust system. When you have extreme backpressure in the exhaust manifold like turbocharged motors have it makes it harder for the motor to inhale air when the intake valves open during the over lap before the exhaust valves have closed due to the backpressure. The main reason it isn't usually suggested to use hotter cams on a turbo motor is due to the fact that with longer duration comes more valve overlap. With more valve overlap come less exhaust energy at lower rpms where the cam is not designed to make power. With less exhaust energy at lower rpm's comes more turbo lag, and so on...
As for these negative side effects on turbocharged motor, in my understanding and expericance. They only apply at low rpms and show nothing but positive effects at high rpms just like they would in a n/a application.
Since a supercharger is not dependent on exhaust energy to make boost, it will not see the same negative side effects from hotter cams as a turbocharged motor might.
As for the original question, my cams have .410" lift and 212 degrees of duration. 212 degrees is a decent amount of duration over stock but is not really considered to be a very hot cam and is not too much for a turbocharged engine.
Thanks for the information. I have a new set of HO cams, but I wanted to find the best cam for my SC application. Hopefulley I can use the specs to match the cam to my cylinder head.
Jason
99 Z24
157hp/171tq
wheres my boost??
Skilz10179 - ahh i see ... we were just on 2 different paths there for a bit... i get what you were trying to say... but im also asking about for my set up since yes i have the supercharger but also have the turbo back there too remember... so a bigger over lap for me would not be the best ... i think im just going to let JBP decide the specs as i am having them build the engine for me, since they know the oiling problem of the LD9 where as a local engine builder might not...
Josh F wrote:Skilz10179 - ahh i see ... we were just on 2 different paths there for a bit... i get what you were trying to say... but im also asking about for my set up since yes i have the supercharger but also have the turbo back there too remember... so a bigger over lap for me would not be the best ... i think im just going to let JBP decide the specs as i am having them build the engine for me, since they know the oiling problem of the LD9 where as a local engine builder might not...
Maybe i wasn't very clear. The longer duration will hurt lower end power by adding turbo lag but add tons of power on the top end of the power band. Since you don't have to worry about turbo lag as much because of the supercharger it shouldn't effect your low end power any more than it would on a n/a motor.
Compare any aftermarket cams vs stock cams for factory turbo motors, they all have longer duration and they are all a lot hotter than any cams out there for our motors unless they're a custom grind.
My current cam setup.... w/ stock cam timing
Intake: 200* @ .050" with .375" lift
Exhaust: 212* @ .050" with .410" lift
Possible future cam setup..... w/ 2* intake advance / 2* exhaust retard cam timing
Intake: 212* @ .050" with .410" lift
I also have a set of PowerTek cams that need to be spec'd out...... w/ +/- 4* gears
For Reference
*** Comp Cams Street/Strip N/A EcoTec Cams ***
Intake: 216* @ .050" with .440" lift
Exhaust: 218* @ .050" with .436" lift
(more over lap)
*** Comp Cams SuperCharge EcoTec Cams ***
Intake: 210* @ .050" with .423" lift
(less over lap)
*** Comp Cams Turbo EcoTec Cams ***
Intake: 204* @ .050" with .423" lift
Exhaust: 200* @ .050" with .419" lift
(least amount of over lap)
Edited 1 time(s). Last edited Tuesday, November 28, 2006 1:46 AM
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
WOW...with some of this information in mind...and assuming the LD9 and eco react the same way to differenct cams...which is kinda bull@!#$ but for the sake of saying I'll make that assumption. It would say that although the HO cams are a bit aggressive on the overlap for boost, but the lift is about appropriate for the goal. Maybe some degree cams to advance the intake and retard the exhaust to reduce some overlap and you'd be pretty close to ideal. Or so the assumptions made would say so.
