hey does the stock ecu hold up for boost? or do i need a reflash of some sort? or just a tune?
You should be able to get the GM S/C reflash done. You also need a new MAP sensor with this. DO a search for GM S/C reflash should be able to find some info
2nd Place is the first loser
There is no reflash for the 2200, as well as no GM supercharger for that motor. It is ok for a small amount of boost, but a good tune will help you greatly.
ok. well i just finally got a custom turbo kit together. i was just wondering so i know what to do. probably get it tuned with the safc on a dyno.
use HPtuner software
