After hooking up my wideband 3 weeks ago Ive noticed my afr at idle is 10:1. This is rediculous for an LD9 with 310cc injectors and a stock FPR.
Now I am in the midst of considering an AFPR to fix this but I dont think the fpr is completely causing my problem. Im assuming that my afr is so rich at idle because of my spark gap and im wondering if this is possible. My car is a 99 (no hp tune) and currently has the rapid fires that come with the SC kit (didnt touch the gap when I got them). Before I had the 310cc injectors (rode on stock injectors for 2 weeks), my car burned too much gas already. In fact, both now and before the injectors a full tank would only get me 300km or 186 miles and thats without touching boost! N/A my car got 550km to a full tank.
So im kinda skeptic about using an afpr to solve my problem since I have seen other owners using the stock ones on an LD9 and still hitting near 14.7 afrs. So what do you guys think, do I just get the afpr and tweak it down? Should I gap the plugs higher or lower, if so whats best?
I really cant wait till the summer to get the HP tuners so that I could advance the timing and what not, but for now I cant stand the balls of black smoke that comes out when I ram my car!
One more thing, whenever im at WOT, whether im downshifting from 5th to 4th or going from 3rd to 4th at higher rpms my car seems to "bog", or it feels like its lagging. I dont really think its leaning out, im guessing this has to do with the spark or maybe it really might need a bit more fuel etc.. At WOT my afr is 12.7-13.2.
What do you guys think?
Heres a pic of the log file with the wideband. This starts from an 80km/h role in gear 3 (50mph), when I shift to gear 4 thats when you see a spike (6,16.5 on the graph) and then it spikes really high again cause I accidently hit the governor (only 2 shift points cause I didnt go to 5th). When I went from 3 to 4 my car lagged, can anyone see why by looking at the graph?
you seeing 5 psi now on the boost guage?
How you been Jake? Nope not yet still getting 3.6-4psi. Schools been keeping me away from my car but I did find this...the hose coming from the evaporative canister was rubbing on the SC belt. It cut a hole in it, enough to stick your finger in!! !Vacuum constantly runs through that hose along with fuel vapours, so im assuming theres my vacuum leak which is why I have an incorrect reading on the boost gauge. But anythoughts on my afr?
Do you have the GM reflash? Nevermind i didnt read you have a 99
Ok heres what you need to do and theres a thread on this in the tuning forum by Shifted
Here you go
There is another step that should be added to this process to get accurate data and that is disabling deceleration fuel cut off or DCFO , reason being is that while driving the moment you let off the gas the chart will show you as being lean cause your AFR drops to 19.9 AFR in DCFO mode and the hp tuners sees that as being different from the commanded 14.6 so it shows as a lean spot on the histogram
its always going to go back and forth be sure that the A is selected at the top of the histogram so your getting average values rather than min or max values, as long as your seeing 0 to -5 in the cells you should be fine
Follow the steps listed in that post and when your done making changes remember to reset the DFCO and closed loop, always make a backup of your stock tune before starting this process, I think if you follow all of this you will be just fine
Matt, I'll definetely take that into consideration when I get HPT. Chris, always good to hear from ya man! I honestly cant stand the amount of gas my car burns, you walk to the back of my car and you can almost sniff it. Is there anyway to make sure it has nothing to do with spark gap, im afraid one of the cylinders isnt firing or something yet the only code I have is a "rich" code.
But I never thought crusing at a 10:1 ratio, or getting the SC alone would double my gas consumption (was burning so much with the stock injectors which is why I think its the spark gaps). Nonetheless, what do most of you have rapidfires gapped at in a pre 2000 application?
given your situation the rich code is pretty much a given, same thing happened to me when i put in 310s and didnt have any way to adjust the computer or fuel pressure
it has nothing to do with spark gap, as far as the AFR however your plugs are prob covered in Black to go along with your rear bumper, if your not firing , you will know and you will have a 300-304 code showing
Hmmm...this is interesting.
Although I'm not thread jacking my car is about the same as yours...difference is I have the ECO with the SC. SC lags at times, fuel milage is crap and idles pig rich!
Nothing I can add to assist you but odd we have the same problems but on different engines?
I'm replacing my injectors as I've tested and had tested every possible thing I could come up with and everything GM could come up with...they say bad injectors...I say fine....send me some...they say ok!
Good luck with yours!
when you hit 139 ECT it shouldnt have any issues with stalling, at least on the eco, that used to happen to me till i could fix with hp tuners
BlueDuece - you running the GM flash and GM supercharger injectors?
Rodimus Prime wrote:BlueDuece - you running the GM flash and GM supercharger injectors?
Yep...waiting on my new injectors from GM right now to see if that fixes it!
Who knows maybe the lagging is normal? Yup my bumper is all black! I guess Ill leave the plugs the way they are and just get the afpr, bluedeuce, id suggest the same to you and ill let you know what happens.
BlueDeuce (dnt02cavls) wrote:Rodimus Prime wrote:BlueDuece - you running the GM flash and GM supercharger injectors?
See this proves you 2 have 2 different problems. Can't compare your problems because you have a reflash and he does not. I had this same issue on my 96 Turbo cavy. When we put a AFPR on we could make it idle nice. You could adjust your plug gap, but that could cuase you isses when you are in boost. HPT would be the better option.
sam, i say try the stock injectors, a better fuel pump and a FMU.
