I was just wondering what your guys intake temps are. Right after I get off the throttle, it's around....160. Cruising at 75 it sits at 120. It's strange cause when it was 40deg out instead of 80 my cruising IAT was 80ish.....I have meth injection too....but I need to upgrade the lines so I can run alky.....
So what are your IAT's?
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
around there....  little lower. maby 135-150
when im spraying watter it goes round 100 though.
Chris
'02 Z-24 Supercharged
13.7 @102.45 MPH  Third Place, 2007 GMSC Bash  SOLD AS OF 01MAR08
when it is 20'c outside I run around 22-23'c, and under full boost upto 27-30'c.
having said that, if I want to do some hard runs with water/meth, put the tank in the freezer and cool it down to 0 or -10'c, and you intake temps will drop well below atmospheric.
my normal driving temps are around 125-140.  wot is around 150-165.  no alky.
