I'll measure mine tonight. I have to go to work now though.
I'm running those exact injectors... they're way too big for your current mods and too small for 20psi.
Built, bottled, ready for 11s. 14.446@93.74mph, 1.848 60' N/A.
Owen wrote:I'm running those exact injectors... they're way too big for your current mods and too small for 20psi.
Wait, are you saying that you have those EXACT SAME INJECTORS?? did you buy yours from that guy on ebay? the same listing and everything?
How long were these green top compared to your stock injectors?
Im in progress of turbocharging my car, i dont think they are too big...
My CarDomain!!! ---
http://www.cardomain.com/ride/2543660
check for these spacers on your car.
did you get the 95-99 style injector wires yet?
2002 ECOTEC Fuel System Upgrade: As some of you know, the 2002 ECOTECs use a different fuel system than the 2003-2005 ECOTECs. The 2002s have different Injectors, Fuel Rail and Fuel Pressure Regulator. The 2002 Injectors are also longer than the 2003-05 ECOTECs. On the newer ECOTECs, GM used a spacer between the head and the actual Injector to make up the size difference between the tw injectors. If you use those spacers on your 2002 ECOTEC by putting them in between your injector and the head, you will be able to use the fuel system from the 2003-2005 ECOTECs.
from
here
14.82 @ 97 mph
Jasonoshawaz24 wrote:check for these spacers on your car.
from here
I have a 2005 ecotec, im not upgrading from a 2002 ecotec or anything, what are you trying to say?
Im asking if those ebay injectors will work in my car because they are only 60mm long and my stock 2005 ecotec's injectors are 82mm long...
My CarDomain!!! ---
by that post it sounds like the 03-05 ecotecs use the shorter injectors with a spacer. so the 60mm ones might fit unless someone here gives you the direct scoop on it.
14.82 @ 97 mph
Hmm, well there is this guy that measured his Ecotec injectors and told me that they are 82.5mm long from the VERY top to the VERY bottom of the injector...
The guy on ebay that is selling these green tops said that
The injector is measured from the bottom of the top O-Ring to the Top Of the bottom O-Ring. If you measure on any other part of the injector, you will not get a valid measurement.
My CarDomain!!! ---
So maybe if he measure his injectors from the VERY top to the VERY bottom then maybe it will be longer...
You know what i mean?
My CarDomain!!! ---
