Does anyone out there have detailed pics of there install?! I can not figure out how in the hell you all got a down pipe on this thing without burning up the fuel and heater core lines.
I extended my fuel lines and my heater lines were tie wrapped to something else. Nothing melted.
the lines should be ok aaron....
i don't think anybody in jbom with the set-up has had any issues
anyone got close up pics?
you have to bend the heater core lines(hardlines) just enough so it fits.
Is it one of brandosons downpipes? if so it helps to bolt it to the turbo then attach the turbo to the manifold
here are some pics that may be helpful
disconnect you fuels lines and move them to the other side on the heater core lines, then get a 2.25in P clamp and put all four lines and hoses in it, then make a bracket for the clamp.....done.
so what should you use for the heater core line, because that seems to pretty close and it is a rubber line.... And Chad I just looked at a picture I took of you setup at the bash I know what you mean now.
slaab sux!!!!!
THERE CAN BE ONLY ONE, i have already died once and im still here so lets just leave it on the track
