Maybe you should try calling innovate they do over the phone diag. You coulda gotten an answer faster than you typing this rant...........
mine did that same thing resently, i found the power wire to the unit had a very loose connection. Remade the connection, and all is good.
M90'd Built LGO-15 PSI
http://webstarts.com/quadper4mance
yeah it is showing lambda.
you need to set it correctly before going and calling it a pos. The only problem I see currently is the user.
I'd also suggest that you calibrate it to, how often do you do that as well?
LE61T PTE6262 Powered
funny........ any issues i have ever had with innovate took less than 5 minutes on the phone to solve any problems. Your boss is a FAG and you should look for a new job.
it should not be a heat sink issue. If it were it will definently throw a code. The readings can and do go as high as you are explaining when exposed to atmosphere but will usually default to 20:1 or "O2" after a few seconds. It is also possible that the sensor itself has shorted out as it is common for that to happen also be sure the little plastic pigtail at the sensor has not been kinked or pinched off in anyway as this can cause such readings as well. Being its a holiday contacting innovate is not really relevant for an immediate resolve to your issue. The innovate can also pick up interference from exposed wires from the unit that are not being used and should be taped off. (don't know if you have any but it is also a known innovate issue. Just to clarify as well its 14ppm air to 1ppm fuel.....
oh wow you have that big hunky thing? i just had the gauge.
See when I calibrated mine in free air I had to let it calibrate for 30 seconds.
I suggest calling innovate. Mine did that exactly what yours is doing and I calibrated mine and then it worked but I only had the gauge.
Lefix wrote:Ohh man, i was just gonna get an innovate wideband for my turbo project too...
Now i think im gonna buy something else.. yuck
Don't be stupid.
" To study and not think is a waste. To think and not study is dangerous. "
The innovate standalone gauge is definently the way to go in the world of wideband systems on the market. It does have its quirks but it is by a long shot the MOST capable and accurate system out. Has MANY MANY cool options when hooked to the laptop and is expandable. Once configured and setup the way you like. Its maintenance free with the exception of by-annual calibrations. I think at this point you need to call innovate for a resolution as there are to many factors that could be effecting your units readings.
Yeah i heard alot of good stuff about Innvoate too...
Which innovate model is the BEST wideband kit? Should i get the the LC-1 Sensor with a gauge of my choice?
or is there a better kit available for me? I have money so expensive isnt a problem...
I really need help cuz this is one of the 3 things i need to buy to get my turbo in...
Thanks guys!
My CarDomain!!! ---
http://www.cardomain.com/ride/2543660
how about the bosche wideband? how does it perform?
Magnaflow Muffler in Classifieds... New In Box
HELFENBEIN wrote:I would have to put into question the durability of the Bosch product, though there are many things that I could have done wrong (but to the best of my knowledge, everything was operated properly) and I'm also sure that there a billion people out there who have never had issues with the Bosch sensor.
Post a picture of your sensor placement.
