Is this kit on advancedjdmparts for 2200 cavaliers legit?  Why so low in price?
ok brett heres some answers
i would advise against buying parts for a domestic car off a JDM website, duh
second i wouldnt buy @!#$ off a site that lists a cavalier header for the 2.0 liter engine, seeing as though the cavalier never came with a 2.0
third it looks like all that @!#$ is cheap cheap cheap, plus the turbo kit comes with 0 fuel mods so you would still need to get bigger injectors, a fuel pump, colder plugs and that doesnt even include a tune
basically it is low in price because it is low in quality
first of all avoid them
second of all don't believe everythign you read on the internet casue this next statement......
pure ignorance
there is a 2.0 cavi
just casue its not a 3rd gen doesn't mean its not a cavalier
here you go ryan
and yes i know the cavys in the 80s had a 2.0 but the above was what i was talking about
see now your making sence... in your original post you said Cavaliers NEVER came with a 2.0... no mention of years or anything, just that they never had a 2.0
Don't forget the Vauxhall Cavalier...It came with a 2.0 as well.
"Youth in Asia"...I don't see anything wrong with that.
Back from the dead..... so what's wrong with the turbo kit? just cause it doesn't come with fuel injectors a fuel pump and a tune it's crappy hardware?
I bought cheap JDM parts and it was a mistake. The turbo didnt last but 2 days till it leaked.  Dont make the mistake of going cheap, and buy something worth the extra money.  You will be much happier in the long run.
Believe me, its hard to think that just because its not name brand means its junk.  But they're stuff really is junk.  Your gonna have to buy parts later on to cover the failures.
www.bradsairsoft.com
$1100 IS TOO CHEAP!!!!! I wouldnt trust it!
FORGED WISECO PISTONS 350
FORGED EAGLE H BEAM RODS 350
SEALED POWER MAIN BEARINGS 80
SEALED POWER ROD BEARINGS 80
COMETIC MLS HEAD GASKET 120
TOGA HP PORT FLOW STAINLESS INT/EXH VALVES 100
TURBO TECH UPPER RACING ENGINE MOUNT 120
TURBO TECH LOWER RACING ENGINE MOUNT 100
MITSUBISHI BIG 16G PORTED 7CM EXH 34MM INT WASTEGATE 750
CUSTOM STAINLESS LOG STYLE MANIFOLD 350
FRONT MOUNT INTERCOOLER 200
ADJUSTABLE FUEL PRESSURE REGULATOR 80
GM 3 BAR MAP SENSOR 50
2.5” INTERCOOLER PIPING FULLY WELDED 350
ARP HEAD STUDS 250
ARP MAIN BOLTS 125
VACUUM MANIFOLD 25
HKS SSQV BOV 220
650 CC RC ENGINEERING INJECTORS 550
SNOW PERFORMANCE METHANOL INJECTION 450
WALBRO HIGH PRESSURE 255 LPH FUEL PUMP125
EXTERNAL OIL COOLER 60
EXTERNAL TRANSMISSION COOLER 60
That alone is around $4945, without my exahust ($1655) and without my suspension ($1175)! Add your taxes, time, misc bull @!#$, and your around $7720 to have a fast well handling cavalier!
