What plugs are you running and what are they gapped at?Gona be just a basic turbo setup on around 7psi, prolly gona go with the delco R42LTS 1 step colder plugs, or is there something else recommended and gapped at what with the coil swap?
I recently did the ohv coil swap using ngk tr55's gapped at .060, great mod btw.
Anyone? I know some of you turbo ld9 guys are running the tg coil swap or whatever,help me out!
Mine isn't the TG coil swap, actually my own coil swap
  But im running TR6's gapped at .28.
2012 numbers - 4SPD
AUTOMATIC!!
.028.  TR6.
Chris
'02 Z-24 Supercharged
13.7 @102.45 MPH  Third Place, 2007 GMSC Bash  SOLD AS OF 01MAR08
Cool thanks guys. Whats a good n/a with using the coil swap?
I also think Ill go with the tr6's instead of the delco's when I turbo soon. Im using tr55's now and did in my old car, ngk are good plugs; never had any problems with them.
Bringing this back, should I still gap the plugs around .028 with the gmsc kit instead of a turbo setup? Still have the 2.2 coil swap
You should be fine with TR6's  gapped at .050 That is what mine are gapped at and I still have the stock setup so if you have a stronger spark with the 2.2 swap then you should easily be able to run them at .050 You do not want to go any smaller of a gap than you need and .028 is pretty extreme. If you are experiencing spark blow out then step it down .005 at a time.
