I know ALOT of people use the Mustang Cobra Heat Exchanger, but what does everyone else use?
I want mine to look nice.  I was looking at one that looks like an Intercooler for a Turbo, BIG AND SHINEY.
  I know it is a little overkill, but it will work.
So what do you use?
fluidyne makes a huge cobra upgraded one, its big and shiny and will support more hp then the m62 will ever make. its about $320 i believe so not to bad of a price either..
I use a LFP Extreme Intercooler Heat Exchanger 2003-04 Mustang Cobra (bought off eBay)...cost $199
Here's the actual web site:
http://www.lightningforceperformance.com/lfp-extreme-intercooler-heat-exchanger-200304-mustang-cobra-p-318.html
Here are a few pics...I may end up cutting in to the bumper support this summer though and actaully mounting it flush with the radiator (once I remove the AC)...make it sit up in the bumper some more....
...and as you can see in the pics...I had tabs welded to the top of mine to mount to the underside of the bumper support
It's 18 fins per square inch...I think the size is 9X27X3 but not sure...
Edited 1 time(s). Last edited Wednesday, December 26, 2007 4:16 AM
i'm running an aftermarket cobra heat exchanger made by AFCO.  here is the link
AFCO Heat Exchanger
BLWN L61 wrote:i'm running an aftermarket cobra heat exchanger made by AFCO.  here is the link  AFCO Heat Exchanger
oh man those are expensive. was looking at those too. then a garrett heat exchanger from a cobra was put on ebay. so i bought it. $75 max, can't remember the amount.
_______________________________________________________________________
my carDomain updated 11/5/07 I've got premium. Yes I do. I've got premium. How 'bout you?
yea the mustang heat exchanger is more than enough and very efficient.
1. its made by garrett
2. If it can support a a supercharged v8..... im pretty sure it can support more than enough power for any 4 cylinder on the m62...
Do you have the Part # for that RESIVOUR?  That is the one from the REDLINE and the SS, right?  It bolts DIRECTLY onto the Frot of the charger?
If you have the Part #'s that would be GREAT
I think I may have the part number for that at work, I'll check tomorrow. I have it on mine but I could only use one of the bolt holes on the bracket  because it sat to high and hit the hood, other then that it works really good.
You'll have to mount the resivour to the radiator support.  It will not work in the same place the SS/Redline does.
I actaully have never mounted mine...the way I have my hoses ran it just sit up all nice and pretty on it's own!  Kind of weird that it does...but it does!
I can wait to install mine.  I repolished it and WOW is it shiney!
MIne will be ported and polished once I return....
Can't wait to see it!!
here are the part numbers for the reservoir.  my reservoir is mounted to the radiator support
GM Parts Direct
Reservoir 22697069
Bracket 22707614
Cap for the reservoir- 15076936
AFCO dual pass and GM Reservoir....Hey  BlueDeuce  i might be going to the strip JAN 1 if its not blow 0 out and 6 inches of snow,there having a hang over fest and ill get ya a video
later
What pumps are you guys running?  Also where did you mount them?
James (ROLN19S) (JuicyJ) wrote:What pumps are you guys running?  Also where did you mount them?
ah ha. thanks for asking. this is what
reservoir i'm lookin to use, just need the pump.
I bought the ZZPerformance one...you'll need the Pump 4 - GM on the drop down menu...do not selct any options as the manifold and SS resevior are all 3/4 inch inlet/outlets....as well as the Heat Exchanger (the one I posted and most others I think)...everything will match up.
http://www.zzperformance.com/grand_prix/products1.php?id=425&catid=139
I mounted mine to the bottom radiator support (on top of it sort of....more like to the side facing the engine).  Used large clamps to hold it in place.
Also ran a relay of it to the ACC power source inside the car.  This way it's only on when the key is turned on.  Ground to the frame.
Edited 1 time(s). Last edited Saturday, December 29, 2007 6:48 AM
The same pump Fastcavz24 bought, with cobalt mount:
Resevoir/intake:
Heat exchanger:
Edited 1 time(s). Last edited Saturday, December 29, 2007 6:19 PM
Looks good Tom! Glad to see you got around to finishing it? Do you put the header on yet?
FstCavZ24 wrote:Looks good Tom! Glad to see you got around to finishing it? Do you put the header on yet?
lol, no. Looking to get the header put on with a custom downpipe in 2.5 all the way back.
For the coolant tank, does that just hook up with a T- fitting?  Also, does it need to be mounted higher than the pump, or does that not matter?
James (ROLN19S) (JuicyJ) wrote:For the coolant tank, does that just hook up with a T- fitting?  Also, does it need to be mounted higher than the pump, or does that not matter?
There's two hose connections on my resevior (cobra mustang 03-04). The top is return the bottom is feed. and I would mount it higher than the pump.
CX Racing 176 shipped off ebay, its awesome
