how does one measure intake air temperatures in your engine?
I see everyone talking about how low they get theirs...  but how does one monitor this?
Also,  how can you measure boost on the MP45 (GMPP SC for 2.4l)
I ran a boost gauge Tee-ed off a vacuum line before, but it screwed with things.  is there a more accurate and les intrusive way to run a boost gauge?
my poor baby is sick...  someone help me...
(2.4L engine in my cavy is ticking bad...  need to make it stop)
You have an IAT sensor in your intake or intake manifold.  You can monitor it with HPTuners or a separate temperature gauge (it might have to be programmable though).
I run my pressure gauge off of a T with the FPR vacuum line.  Gives me the same reading as it having its own vacuum line.
"Youth in Asia"...I don't see anything wrong with that.
you need to make 10 more threads to find the answer and press alt F4 to see the results
Haha thank you Vincent!  Glad I'm not the only one...
14.330 @ 96.37mph
LOL!!!, I monitor mine through HP Tuners
Jason
99 Z24 Supercharged
157hp/171tq - NA
LD9 for Life
I use HPTuners... and yeah I was thinking the same thing lol
" To study and not think is a waste. To think and not study is dangerous. "
Vincent Morris wrote:you need to make 10 more threads to find the answer and press alt F4 to see the results
_________________________
I just have mine T of the FPR as well.
yo wade....did you get my emails?
i got my boost/vac gauge hooked up....
what should the gauge be measuring off of the FPR when "idling" at 4k in neutral parked?
boost or vac?
I"m getting vacuum like a N/A car would...dunno if this seems right
You guys aren't alone. Every time I see that a new post was made by "ken soggs" I cringe.
Just messin with ya Ken.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Ian Irrgang wrote:yo wade....did you get my emails?
boost or vac?
Is it idling at 4k by itself? or with your foot on the pedal? cause if its by itself that is a problem, probally a vaccuum leak.
However im pretty sure you need to put load on the engine before it will start making boost. Try putting the car in drive, foot on the brake and give it some gas, the car wont move but you should see it start to build boost.
If you can't hook up a boost gauge then you shouldn't have boost in my opinion.  Vacuum should be around 20 in. Hg. and altitude has some play on this as well.  A simple T from any parts store will work and just make sure its the right size and doesn't leak.  Also make sure you don't have any kinks or cracks in the hose going to the gauge.  And if you engine is ticking like your post says, sounds like you have bigger things to worry about.  As for a 4K idle, you need to figure out what the deal is cause something isn't right.  Good luck diagnosing that one.
~Boost. Its what's for dinner!~
