I recently supercharged my ecotec. Where the valve cover breathes into the little pvc filter is leaking oil. The filter used to be dark blue and now is dark greenish. I'm wondering if I came across a bad filter or need to try a different method. When I first bought and put on the APC filter I put it on to far I think and started thinking. I thought by adjusting it to be on right would make it stop. Maybe I damaged the rubber part and its leaking?
Thanks in advance for your input/experiences!
2005 LS Auto (Blue)
-M62 Kit with 3.1"
-ZZP S3 H/E setup
-Pacesetter armor coated header
-Magnaflow 22" resonator (p/n 10436)
-Vibrant CatBack
-TTR Upper and Lower motor mounts
nothing?
2005 LS Auto (Blue)
-M62 Kit with 3.1"
-ZZP S3 H/E setup
-Vibrant CatBack
its probably just a case of blow by. My turbo Buick would do that all boosted cars do that. The power adder is puttin air in and it slipping past the rings the goes in to the crank case a small amount comes out.
does anyone know of anything stronger than?
2005 LS Auto (Blue)
-M62 Kit with 3.1"
-ZZP S3 H/E setup
-Vibrant CatBack
yellow cavy (s/c L61) wrote:get a catch can thats what i have been meaning to do. my eco does the same thing with the blower on it.
wheres a good place to find one that fits?
2005 LS Auto (Blue)
-M62 Kit with 3.1"
-ZZP S3 H/E setup
-Vibrant CatBack
they are all universal, just find one that is the right size for the area you want to put it in.
John Benham wrote:they are all universal, just find one that is the right size for the area you want to put it in.
lol i have a universal one that "fits just perfect" still leaks....
2005 LS Auto (Blue)
-M62 Kit with 3.1"
-ZZP S3 H/E setup
-Vibrant CatBack
Did you remember to modify the intake manifold gasket?
14.330 @ 96.37mph
BlownBlackZ wrote:Did you remember to modify the intake manifold gasket?
yep sure did....y?
2005 LS Auto (Blue)
-M62 Kit with 3.1"
-ZZP S3 H/E setup
-Vibrant CatBack
