For those who have installed their GM Kits...Whats the install time? Also, what size pulley are you running?
I called GM also and the Reflash is $200...Is it safe to drive the car after install until I get the reflash?
I'm thinking as long as I don't get into boost which may be difficult...
ALSO...The only kit I can find is from Summit Racing...Has anyone located something less than $3,000?
Thanks
Brian Toney wrote:For those who have installed their GM Kits...Whats the install time? Also, what size pulley are you running?
i hear general rule of thumb is to set aside a weekend.
yes, from where you are to where you're getting the comp flashed.
search about the bypass plate and how to make it stay open.
Thanks
try gmpartsdirect, createenginedepot, or the classifieds here.
Nice alright well gmpartsdirect is a no go and ill try the classifieds as well and ill check out the bypass plate...Thanks dude
12 hours of constant work it will be done
Book time is 4.0.
fastest I've done it was one hour.
Chris
'02 Z-24 Supercharged
Can the 00-02 Jbodies run with the 2bar plugged in? I was under the impression to drive somewhere for the reflash with the 1bar, and swap out before reflash...
I would count on a full weekend to do it. It's a pretty well designed kit though, if you have the tools you shouldn't run into any big problems.
" To study and not think is a waste. To think and not study is dangerous. "
Your First Install every, step aside atleast 8 hours between a weekend or so and keep the manual/instructions handy.
My first install took 8 hours between two days. Now, I can get a complete install done plus heat exchanger in about 2.5 hours. given everything is already supplied and no beer/Auto supply runs have to be made.
Excellent, doesn't sound to difficult then
