So low or high pressure turbo for the saab turbo whats the difference?
does hi and low pressure mean psi or cfm?
horsepower is how hard you hit the wall, Torque is how far you push the wall with you
I believe its psi.
I tested both on my car and couldnt tell the difference. I was running 6psi.
I did test the LP to 12psi though. I didnt try to go higher.
both turbos made for a very fun daily driver cavalier. Instant power since the turbos are small and the 2" charge pipes I made.
"Growing old is mandatory. Growing up? Definitely optional."
Different turbos the high pressure turbo has a larger compressor housing.
yeah the LP is a garrett (cant remember model) and the HP is a mitsubishi TD04
