I have an L61 and i wanna turbo charge it as well as a supercharge it. as well as have an intercooler or H/E
anyways what kinda setup is it that is recommenced. i know that its can get around expensive but what are all the parts i would need to complete a project like this.
and how it  would look as far as the setup.
and id wanna Hpt it.
thanks on the info
OEM CAMBER/CASTER KIT 10 People for $210 <P>
GOT ECOTEC?
I'm thinking if you don't already know, don't bother.
This topic...sucks.
14.330 @ 96.37mph
I would not recommend it. Supercharger creates sooo much heat. Plus the money involved for doing both, you could do a really kick ass turbo set-up.
grab a gm build-guide and go nuts, forget your original idea. one of the problems you would encounter is controlling both compressors and using them sequentially or staged. could be controlled by a bypass valve on the s/c that would stop the flow through it when reaches its cfm rating, then the turbo takes over.
Use the money for a GM S/C and some serious internals and turn that boost uppppp
Don't do it at all, go turbo only. You are welcome.
"Never argue with an idiot. They'll drag you down to their level, then beat you with experience!" -Anonymous
