Where can I buy this turbo kit for the 2.4L LD9 i'm reading about but can't gat a site?
I'm making mine turbo on stock motor and want to know how much boost can it take?
What size of injectors  and turbo should go in?
If I should use an APEX for managing the fuel? (I think it's a good idea)
What modifications should I make?
Fuel regulators and fuel pump?
Sounds like you need to try the Search button.
- no kit, you buy the parts and put them together
- it depends
- it depends
- it depends
- it depends
- not usually
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
I'm not usually one to say anything, but I just had a little laugh over this one...will be interesting to see what pops up.
There is a good amount of info on this topic. Use the search and check out the stickys, the info is there, trust me I have the same engine and am doing a turbo build soon as well.
thats right i have one  too and all my parts  have been purchased separately , you wont find any plug and play kit .. ill recommend you to read  the boost section as well
