Hey i just wanted to know what size turbo guys are running, I currently have a 50 ar turbine 63ar compressor. but im thinking about getting two other turbo's (one or the other not both lol), one is a turbo a local shop has on display, its a garret gt35r they said, and the other is listed in the jbody classifieds right now, its a garret 60 trim, the reason why is because i just dont think my car is making enough hp per lb of boost, I heard a story that i refuse to believe today, a guy that is a freind of mine has a civic si 08, he is running 10lbs, and he went from 197 bhp to 420 whp thats almost 500whp, that is a 300bhp gain, 30hp per lb of boost????? wtf is this even realistic, on my first tune i got about 230 whp on 9psi, this was a very crappy tune that was done at a dyno shop and since has been corrected (by brandon aka cavfan1 and me), but that was about 10whp per lb of boost which i thought was around average.
if it can't win a race it better win a show
i have a garrett 57 trim 60 AR on my ecotec sunfire
RIP Cpl Derek Kerns And Cpl Robby Reyes
24th MEU VMM-261 (REIN) V22 Crewchiefs
11 April 2012 Morocco (African Lion)
If you plan on a GT35r, you better start building a stronger motor
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LG0/LD9 for Life
Do NOT put a gt35r on a stock motor. Youll blow it up before even reaching half of the turbo's potential. Choose a turbo for what power goal your looking for and what you want out of it. Do some research.
Im currently running a t3 super 60, .60/ .63 which is a good turbo for making 220-250whp on a 2.4. After my motor is built Im planning on going with a holset hx35 with a divided housing. Holset/bullseye turbos can be very similar to many of the garrett gt turbos, only difference being journal bearing instead of ball bearing, but can be had for a quarter of the price.
GT3071R BB
T3, 60-Trim .48 turbine
2002 Cavalier 2200 5spd
anyone need a boost controller
ok I have a spare motor that im planning on building in my garage, but im also looking for a 92-92 short block since that block would be better, i have a 95 2.3, ok the right question i should ask is what do u guys think is a good size turbo to put down about 250whp, im sure the turbo i have now can do it, but i would rather a turbo that can do it with less psi, i had it all the way up to 17psi (accidently, the wastegate was not working, i would never do that on a stock motor purposely) luckily i did not blow the motor. but can anyone answer my original question about my friends civic si making 420 whp on 10 psi, is that even realistic for a car that had about 160 whp stock, gaining 260 whp on 10 lbs,
I'd expect him MAYBE to have 260 total... maybe he has a lot of stickers?
.63-1/.70 is what I'm running on the Sunfire right now
Precision sc61 is what i'm running... .70 compressor .82 turbine. Basically equivalent to a gt35r minus the ball bearing
President/Founder - 607 Motorsports
Super 16G (for 12 second passes) and Super 20G (for 11's!).
Bill Hahn Jr.
Hahn RaceCraft
World's Quickest and Fastest Street J-Bodies
Turbocharging GM FWD's since 1988
www.turbosystem.com
Two of the big ones.
And I'll have them by tonight.
-Chris-
-Sweetness-
-Turbocharged-
SweetnessGT wrote:Two of the big ones.
-Chris-
lol sweetness. so does everyone agree that this guy has to be full of to say he has that much power on 10psi thats a 300bhp gain on 10psi, im no where near a boost pro but i dont think its possible to get 30hp per lb of boost. Also i wanted to know what numbers other guys are seeing with stock motors. i want to be around 250whp, is that realistic. right now im running 10 psi and it was tuned by me and cavfan1 i have not had it dynoed yet since we retuned it but it feels a lot better now
Some motors respond better to turbos. depending what motor he is running id say its possible. It also depends on what other mods hes running.
I'm kinda debating on a TO4E either a 57 trim or a 60 trim. You guys think this would be a good turbo for a built LD9? I'm looking for around 300whp when I get the car out in the spring and will decide after if I am gonna up the boost and go for 350whp. Since this is only a journal bearing wondering what the turbo lag would be like on a turbo like this? I'm kinda aiming for full boost in the range of 3500-4000 for street driving but I just mainly want the car to be fast a the track and when shifting I don't go below 5000rpm. Any suggestions would be appreciated.
1fast 2point3 wrote:SweetnessGT wrote:Two of the big ones.
-Chris-
It is possible, but Id say not from just bolting on a turbo setup. Over 400whp he probably has a built motor, plus tuning for hondas is endless soo he could tune probably 100whp out of his setup alone with the right setup and software. I would get all the specs of his setup and then we could tell you if its BS or not, but if your saying its from upgrading the turbo its highly doubtful.
