What does it take to get to the original pump once the tank is dropped? As in how do I get it out? Details are much appreciated.
"Vroom."
"Yo I wouldn't race him, there's not even an interior in his car man."
"Vrooooooom PSSSSHHH!"
"Oh sh*t. F*ck that, dude..."
Undo all hoses from tank
Disconnect harness from underneath
Drop tank
Undo the snap ring
Lift pump assembly out of the tank.
Disconnect pump to pump assembly clips
Disconnect pump corrigated hose
Disconnect the rubber hose
Take off the filter on the bottom
Take the pump out
Put the new filter on the bottom
Install new pump
Connect clips on the pump to the assembly
Connect corrigate hose
Connect the rubger hose
Put all back together
AHHHH
That's it in a nutshell
So how do I undo the snap ring?
"Vroom."
use a chisel and a hammer and pound it on one of the tabs to "spin" it.
and david, you  forgot removal of fuel level sensor
Lol damnit Vince, I knew something slipped by mind lol
So even with six tabs if I can get one to move it'll "spin" off? And what is this blue colored "disc" with and L-shaped neck on it that sits lower than the fuel pump assembly? I disconnected that line too that connected to the L-shaped neck.
"Vroom."
Okay I got the piece to "spin" off but it seems hung up on something stopping it from pulled out of the tank. What could it be and how do I move on from here?
"Vroom."
make sure it spins all the way out. then pull up on it with pliers
Okay, it's all out and apart. Which wire (yellow and black) is positive and negative? Looks like the wire connector they sent me isn't exact, all I need to know though is which is which and I'll be able to move past this problem by joining the connector they sent me (red/black) and the wires already on the fuel pump assembly (yellow/black).
"Vroom."
Anyone? Lol I'm stuck till I get an answer on the wires...
"Vroom."
Still doesn't tell me which is the power/ground. Great post though!
"Vroom."
I had the same problem with the wire colors and it turned out to be orange to blue and purple to green.
"Never argue with an idiot. They'll drag you down to their level, then beat you with experience!" -Anonymous
Well I have a yellow and black set of wires...
"Vroom."
I can't do it.....
Yellow -to- Red
Black -to- Black
That will get you going there.
Sorry to act ignorant Josh, I just didn't wanna mess this up. But thank you for the answer man.
"Vroom."
Didn't mean it like that, just trying to screw around. I'm bored.......sorry.
Dude it's cool, I'm on spring break. Bored as hell here too.
"Vroom."
1KWKCAV [Jim] i pm'd you regarding your venturi hose that you arent using, give me a shout back please
