Hey guys, my cavy should be getting back on the road here any day as im just waiting for an idler arm for my blower kit
Anyways, I am running the gm tune for now and im wondering... will the blower cams from comp cams make a decent difference on that tune,
and do you think it is necessary to upgrade the valvetrain with those cams?
The other option (besides doing both but thats a ways down the road), is to pick up a zzp pulley kit. Not sure what size to pick up (stock internals
til next year).
What would you guys do aside from telling me to ditch the gm tune and get a real tune lol
had a blown ecotec swapped 2000 cavy, now just an 02 Grand Am, and a 74 BMW 2002...
Well I would say you need a real tune either way lol. But the cams will make more power by making the engine more blower friendly. You should upgrade springs for this. With the smaller pulley you will be getting more boost.  Niether of these will work to their full benefit with the gm tune.
Blower cams wont do you any good on the GM crapflash and you
NEED to upgrade your valvesprings for them.  The computer cant see that you changed something in the engine, so i just keeps on running like it did before.  I only plan on driving my car to get it re-tuned with the GM Crapflash and blower cams.
The GM crapflash runs pig rich and people(including myself) have had good results with running a 3.1" on it.  Any smaller and you start running the risk of leaning out in the higher rpms.
What tinkles said is right.  Im running the 3.0 pulley and the car will blow a little black smoke if I rev it sitting still from being so rich, but I also had a lean code stored .  I'll be switching to a 3.1 pulley soon.
Alright thanks guys, about how much of a difference are people seeing with the 3.0 pulley?
if you get the cams i would drop a pulley size either way if you want more power, you will have less boost if you keep the stock compaired to a stock one without the blower cams, i have a 3" and im pushing about 13psi and i did the blower cams so ill be dropping to the 2.8" cause ill prob loose about 3 psi from the cams, so dropping to a 2.8 will make up for the 3-4 psi loss...
 13.22 @ 105.2
Ty Petersen wrote:Alright thanks guys, about how much of a difference are people seeing with the 3.0 pulley?
Im at 10psi(3.1") and ~220whp with the mods in my profile.  My boost pressures have always seemed to be a bit lower than everyone one elses, but psi doesnt mean power so im not concerned about that.
I already have the MPS on my M62 so since i will be getting retuned for the cams i am dropping down to a 2.9" just to compliment the new mods.
you sure all your lines are tight? im at like 13psi with a 3.0 and i was at about 10psi with stock
 13.22 @ 105.2
I dont have any leaks, as i said before my pressures have always been lower than other.
Tinkles isnt your blower ported? if it is that will make your PSI lower.
EvoFire wrote:Tinkles isnt your blower ported? if it is that will make your PSI lower.
Not to my knowledge.  When i bought it i was told that the only thing done to it was the MPS and i didnt see any tell tail signs that it was ported.  It did come off a 284whp SS/SC though.
I'm only seeing 11 with the 3.0 pulley . There's lots of determining factors as to what psi you see with a specific size pulley .  Mods ,altitude ,temp. All sorts of stuff
yeah i know that, when i was at a race even with my 3" my gauge was maxed out and it goes to 15... so it was probably more, but it was really cold and windy and the wind was blower against us....all i have is intake exh and i hit 13... huh, ah well, what did you guys get with the stock pulley?
 13.22 @ 105.2
Jean  Fortier wrote:if you get the cams i would drop a pulley size either way if you want more power, you will have less boost if you keep the stock compaired to a stock one without the blower cams, i have a 3" and im pushing about 13psi and i did the blower cams so ill be dropping to the 2.8" cause ill prob loose about 3 psi from the cams, so dropping to a 2.8 will make up for the 3-4 psi loss...
  Loosing psi as a result of installing cams is NOT a bad thing.  It's a good thing.  Your making more power with less restriction and heat.
Don't drop a pulley size just to "maintain" a certain pressure; it is not a good reason to do so.  Keeping the charge consistently cool  and running reasonable advance w/o knock and having to run 10:1 afrs will yield more reliable power than spinning the blower faster.
It's your engine, i'm just saying - the blower moves a FIXED amount of air per revolution and making your motor eat that air more easily is key.
i wasnt saying its a bad thing lol, and i dont mean drop to a 2.6, im dropping to a 2.8 to get a lil more power after installing my cams.
 13.22 @ 105.2
Dosnt having your system intercooled drop your boost pressure too? I Have always been wondering why my system is running low boost pressure compared to others. I have the stock pulley on it and only seeing 7-8 psi, seems more like 7 at most times. I always thought it was because my system is intercooled, but i dont see how its could drop 2-3 psi because its liquid cooled and not air cooled......  Also for the bottom vacuum line on the bypass valve, do you guys have that hooked up to anything or just have it open to atmoshere? I dont even have a vacum hose on the bottom nipple of my bypass valve, do you think thats making a difference in my set up? I have also been thinking about getting a 3.1" pulley because of how rich these things run on the crapflash. Something to raise my boost pressure to comp for the excess fuel would be nice probolly make more power too.
CarDomain http://www.cardomain.com/id/TMald123
Jean  Fortier wrote:you sure all your lines are tight? im at like 13psi with a 3.0 and i was at about 10psi with stock
Also what lines you refering too?
i have mine going to my fuel presure reg,  im talking about the vac lines to the gauge, when i first installed my gauge i just slid the one line into the other, but i wasnt seeing the right vac. and i was only hitting about 7psi like you, your gauge read vac?, and the bottom line on the bypass is hooked up to nothing on mine also ...heres a pic of where its hooked up on the press. reg. kinda hard to see
and i have it split for my meth and then it goes to the solid line for my gauge.
 13.22 @ 105.2
Wait i have my fuel pressure regulator hooked up to the nipple off the lower intake manifold, my gauge is also hooked up t-ed off that line too. you dont have your lower bypass hooked up to anything either? mine top vacuum line on the bypass comes straight from nipple on the blower too. how can i check for a leak on the manifold line? guess trying replacing it and then driving too see if it makes a difference. yes my gauge reads vacuum,  It reads like 21 in at idle so i think the lines are good, ill double check the lines, maybe im loosing boost there. Also being intercooled how much boost am i loosing from that? I dont see we loose boost from that since its liquid to air and not air to air.
also i see your running a 3.0 pulley, did you have to get bigger injectors to do that? Also did you have to get re tunned. it didnt say in your profile how your tuned... how much of a gain did you see from your 3.0 pulley i want to get one really bad, but i dont have any tunability running the stupid crapflash1
im intercooled also, i realllly dont think that will have anything to do with your boost, didnt affect mine, i have a 3.0" pulley yes, bigger inj no, and im not tuned for it either, it was faster but id deffanitly get it tuned for it, like i said before im dropping to 2.8" and 60# inj. and getting a proper tune. i havent really updated my profile in a bit so i donno what it says hahah
 13.22 @ 105.2
Just installed the 3.1 pulley.  Boost dropped to 9psi. So down 2 from the 3.0. But the 2 psi drop is well worth it to keep from leaning out. $40 pulley is alot cheaper than inj.,fuel pump and tune or a rebuilt engine lol
